Xrecord 示例
以下 ObjectARX 示例由两个函数组成:和 。第一个函数将新的 xrecord 添加到字典中,将该字典添加到命名对象字典中,然后将数据添加到 xrecord。该函数打开 xrecord,获取其数据列表,并发送要打印的列表。有关完整程序,请参阅 ObjectARX samples\database\xrecord_dg 目录。createXrecord()listXrecord()listXrecord()
void
createXrecord()
AcDbDictionary *pNamedobj, *pDict;
acdbHostApplicationServices()->workingDatabase()
->getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
// Check to see if the dictionary we want to create is
// already present. If not, then create it and add
// it to the named object dictionary.
if (pNamedobj->getAt("ASDK_DICT", (AcDbObject*&) pDict,
AcDb::kForWrite) == Acad::eKeyNotFound)
pDict = new AcDbDictionary;
AcDbObjectId DictId;
pNamedobj->setAt("ASDK_DICT", pDict, DictId);
pNamedobj->close();
// Add a new xrecord to the ASDK_DICT dictionary.
AcDbXrecord *pXrec = new AcDbXrecord;
AcDbObjectId xrecObjId;
pDict->setAt("XREC1", pXrec, xrecObjId);
pDict->close();
// Create a resbuf list to add to the xrecord.
struct resbuf *pHead;
ads_point testpt = {1.0, 2.0, 0.0};
pHead = acutBuildList(AcDb::kDxfText,
"This is a test Xrecord list",
AcDb::kDxfXCoord, testpt,
AcDb::kDxfReal, 3.14159,
AcDb::kDxfAngle, 3.14159,
AcDb::kDxfColor, 1,
AcDb::kDxfInt16, 180,
0);
// Add the data list to the xrecord. Notice that this
// member function takes a reference to resbuf, NOT a
// pointer to resbuf, so you must dereference the
// pointer before sending it.
pXrec->setFromRbChain(*pHead);
acutRelRb(pHead);
pXrec->close();
// Gets the xrecord associated with the key XREC1 and
// lists out its contents by passing the resbuf list to the
// function printList.
void
listXrecord()
AcDbDictionary *pNamedobj;
->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
// Get the dictionary object associated with the key ASDK_DICT.
AcDbDictionary *pDict;
pNamedobj->getAt("ASDK_DICT", (AcDbObject*&)pDict,
AcDb::kForRead);
pNamedobj->close();
// Get the xrecord associated with the key XREC1.
AcDbXrecord *pXrec;
pDict->getAt("XREC1", (AcDbObject*&) pXrec,
AcDb::kForRead);
pDict->close();
struct resbuf *pRbList;
pXrec->rbChain(&pRbList);
pXrec->close();
printList(pRbList);
acutRelRb(pRbList);
父主题: |
GMT+8, 2026-11-12 12:30
