示例应用
下面的示例应用程序实现在加载和卸载应用程序时调用的函数。其初始化功能向 AutoCAD 添加了两个新命令:CREATE 和 ITERATE。 它还初始化新类,并使用该函数将其添加到 ObjectARX 层次结构中。(在自定义对象类示例中进行了介绍。AsdkMyClassacrxBuildClassHierarchy()AsdkMyClass // The initialization function called from the acrxEntryPoint()
// function during the kInitAppMsg case is used to add commands
// to the command stack and to add classes to the ACRX class
// hierarchy.
void
initApp()
acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS",
"ASDK_CREATE", "CREATE", ACRX_CMD_MODAL,
createDictionary);
"ASDK_ITERATE", "ITERATE", ACRX_CMD_MODAL,
iterateDictionary);
AsdkMyClass::rxInit();
acrxBuildClassHierarchy();
// The cleanup function called from the acrxEntryPoint()
// function during the kUnloadAppMsg case removes this application's
// command set from the command stack and removes this application's
// custom classes from the ACRX runtime class hierarchy.
void
unloadApp()
acedRegCmds->removeGroup("ASDK_DICTIONARY_COMMANDS");
// Remove the AsdkMyClass class from the ACRX runtime
// class hierarchy. If this is done while the database is
// still active, it should cause all objects of class
// AsdkMyClass to be turned into proxies.
deleteAcRxClass(AsdkMyClass::desc());
父主题: |
GMT+8, 2026-11-13 14:26
