比较 VBA 或 VB 与 VB.NET 中的错误处理程序 (.NET)
VBA 或 VB 中的错误处理是使用语句完成的。虽然这些语句可以毫无问题地与 VB.NET 一起使用,但建议改用语句。 语句比 AND 语句更灵活。On ErrorOn ErrorTryTryOn Error Resume NextOn Error GoTo Label 可以使用语句重写 and 语句的用法。下面演示如何使用 重写语句。On Error Resume NextOn Error GoTo LabelTry-CatchOn Error GoTo LabelTry-Catch 出错时 - VBASub ColorEntities()
On Error GoTo MyErrorHandler
Dim entry As Object
For Each entry In ThisDrawing.ModelSpace
entry.color = acRed
Next entry
' Important! Exit the subroutine before the error handler
Exit Sub
MyErrorHandler:
MsgBox entry.EntityName + " is on a locked layer." + _
" The handle is: " + entry.Handle
Resume Next
试捕 - VB.NET<CommandMethod("ColorEntities")> _
Public Sub ColorEntities()
'' Get the current document and database, and start a transaction
'' Open the Block table record for read
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
'' Open the Block table record Model space for read
OpenMode.ForRead)
Dim acObjId As ObjectId
'' Step through each object in Model space
For Each acObjId In acBlkTblRec
Try
Dim acEnt As Entity
acEnt = acTrans.GetObject(acObjId, _
OpenMode.ForWrite)
acEnt.ColorIndex = 1
Catch
Application.ShowAlertDialog(acObjId.ObjectClass.DxfName & _
" is on a locked layer." & _
" The handle is: " & acObjId.Handle.ToString())
End Try
Next
acTrans.Commit()
End Using
相关概念父主题: |
GMT+8, 2026-11-13 13:23
