打印设置和页面设置 (.NET)
对象与对象类似,因为两者都包含相同的绘图信息,这是因为类是从类派生的。主要区别在于对象具有包含要打印的几何图形的关联对象。对象不与特定对象关联,而是存储在图形的 PlotSettings 字典中。 对象在 AutoCAD 用户界面中称为页面设置,可从页面设置管理器访问。页面设置可以应用于布局,也可以用作在打印或发布时覆盖布局设置的方法。PlotSettingsLayoutLayoutPlotSettingsLayoutBlockTableRecordPlotSettingsBlockTableRecordPlotSettings 列出可用的页面设置本示例列出图形中包含的页面设置。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.PlottingServices
' Lists the available page setups
<CommandMethod("ListPageSetup")> _
Public Shared Sub ListPageSetup()
' Get the current document and database
' Start a transaction
Dim plSettings As DBDictionary = _
acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, OpenMode.ForRead)
acDoc.Editor.WriteMessage(vbLf & "Page Setups: ")
' List each named page setup
For Each item As DBDictionaryEntry In plSettings
acDoc.Editor.WriteMessage(vbLf & " " & item.Key)
Next
' Abort the changes to the database
acTrans.Abort()
End Using
using Autodesk.AutoCAD.PlottingServices;
// Lists the available page setups
[CommandMethod("ListPageSetup")]
public static void ListPageSetup()
// Start a transaction
DBDictionary plSettings = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId,
OpenMode.ForRead) as DBDictionary;
acDoc.Editor.WriteMessage("\nPage Setups: ");
// List each named page setup
foreach (DBDictionaryEntry item in plSettings)
acDoc.Editor.WriteMessage("\n " + item.Key);
// Abort the changes to the database
acTrans.Abort();
创建新页面设置本示例基于当前布局创建新的页面设置。 VB.NETImports Autodesk.AutoCAD.Runtime
' Creates a new page setup or edits the page set if it exists
<CommandMethod("CreateOrEditPageSetup")> _
Public Shared Sub CreateOrEditPageSetup()
' Get the current document and database, and start a transaction
Dim plSets As DBDictionary = _
Dim vStyles As DBDictionary = _
acTrans.GetObject(acCurDb.VisualStyleDictionaryId, OpenMode.ForRead)
Dim acPlSet As PlotSettings
Dim createNew As Boolean = False
' Reference the Layout Manager
Dim acLayoutMgr As LayoutManager = LayoutManager.Current
' Get the current layout and output its name in the Command Line window
Dim acLayout As Layout = _
acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _
OpenMode.ForRead)
' Check to see if the page setup exists
If plSets.Contains("MyPageSetup") = False Then
createNew = True
' Create a new PlotSettings object:
' True - model space, False - named layout
acPlSet = New PlotSettings(acLayout.ModelType)
acPlSet.CopyFrom(acLayout)
acPlSet.PlotSettingsName = "MyPageSetup"
acPlSet.AddToPlotSettingsDictionary(acCurDb)
acTrans.AddNewlyCreatedDBObject(acPlSet, True)
Else
acPlSet = plSets.GetAt("MyPageSetup").GetObject(OpenMode.ForWrite)
End If
' Update the PlotSettings object
Try
Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
' Set the Plotter and page size
acPlSetVdr.SetPlotConfigurationName(acPlSet, _
"DWF6 ePlot.pc3", _
"ANSI_B_(17.00_x_11.00_Inches)")
' Set to plot to the current display
If acLayout.ModelType = False Then
acPlSetVdr.SetPlotType(acPlSet, _
DatabaseServices.PlotType.Layout)
Else
DatabaseServices.PlotType.Extents)
acPlSetVdr.SetPlotCentered(acPlSet, True)
End If
' Use SetPlotWindowArea with PlotType.Window
'acPlSetVdr.SetPlotWindowArea(plSet, _
' New Extents2d(New Point2d(0.0, 0.0), _
' New Point2d(9.0, 12.0)))
' Use SetPlotViewName with PlotType.View
'acPlSetVdr.SetPlotViewName(plSet, "MyView")
' Set the plot offset
acPlSetVdr.SetPlotOrigin(acPlSet, _
New Point2d(0, 0))
' Set the plot scale
acPlSetVdr.SetUseStandardScale(acPlSet, True)
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit)
acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Inches)
acPlSet.ScaleLineweights = True
' Specify if plot styles should be displayed on the layout
acPlSet.ShowPlotStyles = True
' Rebuild plotter, plot style, and canonical media lists
' (must be called before setting the plot style)
acPlSetVdr.RefreshLists(acPlSet)
' Specify the shaded viewport options
acPlSet.ShadePlot = PlotSettingsShadePlotType.AsDisplayed
acPlSet.ShadePlotResLevel = ShadePlotResLevel.Normal
' Specify the plot options
acPlSet.PrintLineweights = True
acPlSet.PlotTransparency = False
acPlSet.PlotPlotStyles = True
acPlSet.DrawViewportsFirst = True
' Use only on named layouts - Hide paperspace objects option
' plSet.PlotHidden = True
' Specify the plot orientation
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000)
' Set the plot style
If acCurDb.PlotStyleMode = True Then
acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.ctb")
Else
acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.stb")
End If
' Zoom to show the whole paper
acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
Catch es As Autodesk.AutoCAD.Runtime.Exception
MsgBox(es.Message)
End Try
' Save the changes made
acTrans.Commit()
If createNew = True Then
acPlSet.Dispose()
End If
End Using
// Creates a new page setup or edits the page set if it exists
[CommandMethod("CreateOrEditPageSetup")]
public static void CreateOrEditPageSetup()
// Get the current document and database, and start a transaction
DBDictionary plSets = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId,
DBDictionary vStyles = acTrans.GetObject(acCurDb.VisualStyleDictionaryId,
PlotSettings acPlSet = default(PlotSettings);
bool createNew = false;
// Reference the Layout Manager
LayoutManager acLayoutMgr = LayoutManager.Current;
// Get the current layout and output its name in the Command Line window
Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout),
OpenMode.ForRead) as Layout;
// Check to see if the page setup exists
if (plSets.Contains("MyPageSetup") == false)
createNew = true;
// Create a new PlotSettings object:
// True - model space, False - named layout
acPlSet = new PlotSettings(acLayout.ModelType);
acPlSet.CopyFrom(acLayout);
acPlSet.PlotSettingsName = "MyPageSetup";
acPlSet.AddToPlotSettingsDictionary(acCurDb);
acTrans.AddNewlyCreatedDBObject(acPlSet, true);
else
acPlSet = plSets.GetAt("MyPageSetup").GetObject(OpenMode.ForWrite) as PlotSettings;
// Update the PlotSettings object
try
PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
// Set the Plotter and page size
acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWF6 ePlot.pc3", "ANSI_B_(17.00_x_11.00_Inches)");
// Set to plot to the current display
if (acLayout.ModelType == false)
acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Layout);
else
acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
acPlSetVdr.SetPlotCentered(acPlSet, true);
// Use SetPlotWindowArea with PlotType.Window
//acPlSetVdr.SetPlotWindowArea(plSet,
// new Extents2d(New Point2d(0.0, 0.0),
// new Point2d(9.0, 12.0)));
// Use SetPlotViewName with PlotType.View
//acPlSetVdr.SetPlotViewName(plSet, "MyView");
// Set the plot offset
acPlSetVdr.SetPlotOrigin(acPlSet, new Point2d(0, 0));
// Set the plot scale
acPlSetVdr.SetUseStandardScale(acPlSet, true);
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Inches);
acPlSet.ScaleLineweights = true;
// Specify if plot styles should be displayed on the layout
acPlSet.ShowPlotStyles = true;
// Rebuild plotter, plot style, and canonical media lists
// (must be called before setting the plot style)
acPlSetVdr.RefreshLists(acPlSet);
// Specify the shaded viewport options
acPlSet.ShadePlot = PlotSettingsShadePlotType.AsDisplayed;
acPlSet.ShadePlotResLevel = ShadePlotResLevel.Normal;
// Specify the plot options
acPlSet.PrintLineweights = true;
acPlSet.PlotTransparency = false;
acPlSet.PlotPlotStyles = true;
acPlSet.DrawViewportsFirst = true;
// Use only on named layouts - Hide paperspace objects option
// plSet.PlotHidden = true;
// Specify the plot orientation
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000);
// Set the plot style
if (acCurDb.PlotStyleMode == true)
acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.ctb");
else
acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.stb");
// Zoom to show the whole paper
acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, true);
catch (Autodesk.AutoCAD.Runtime.Exception es)
System.Windows.Forms.MessageBox.Show(es.Message);
// Save the changes made
acTrans.Commit();
if (createNew == true)
acPlSet.Dispose();
将页面设置分配给布局本示例将页面设置分配给当前布局。 VB.NETImports Autodesk.AutoCAD.Runtime
' Assigns a page setup to a layout
<CommandMethod("AssignPageSetupToLayout")> _
Public Shared Sub AssignPageSetupToLayout()
OpenMode.ForRead)
Dim acPlSet As DBDictionary = _
If acPlSet.Contains("MyPageSetup") = True Then
Dim plSet As PlotSettings = _
acPlSet.GetAt("MyPageSetup").GetObject(OpenMode.ForRead)
' Update the layout
acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite)
acLayout.CopyFrom(plSet)
' Save the new objects to the database
acTrans.Commit()
Else
' Ignore the changes made
acTrans.Abort()
End If
End Using
' Update the display
acDoc.Editor.Regen()
// Assigns a page setup to a layout
[CommandMethod("AssignPageSetupToLayout")]
public static void AssignPageSetupToLayout()
DBDictionary acPlSet = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId,
if (acPlSet.Contains("MyPageSetup") == true)
PlotSettings plSet = acPlSet.GetAt("MyPageSetup").GetObject(OpenMode.ForRead) as PlotSettings;
// Update the layout
acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite);
acLayout.CopyFrom(plSet);
// Save the new objects to the database
acTrans.Commit();
else
// Ignore the changes made
acTrans.Abort();
// Update the display
acDoc.Editor.Regen();
相关概念父主题: |
GMT+8, 2026-11-12 12:33
