分解块引用 (.NET)
使用该方法中断块引用。通过分解块参照,可以修改块,或者添加或删除定义块的对象。Explode 显示分解块参照的结果此示例创建一个块,并在该块的定义中添加一个圆圈。然后,将块作为块参照插入到图形中。然后分解块参照,并显示分解过程生成的对象及其对象类型。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ExplodingABlock")> _
Public Sub ExplodingABlock()
' Get the current database and start a transaction
Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
acCurDb = Application.DocumentManager.MdiActiveDocument.Database
' Open the Block table for read
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
Dim blkRecId As ObjectId = ObjectId.Null
If Not acBlkTbl.Has("CircleBlock") Then
Using acBlkTblRec As New BlockTableRecord
acBlkTblRec.Name = "CircleBlock"
' Set the insertion point for the block
acBlkTblRec.Origin = New Point3d(0, 0, 0)
' Add a circle to the block
Using acCirc As New Circle
acCirc.Center = New Point3d(0, 0, 0)
acCirc.Radius = 2
acBlkTblRec.AppendEntity(acCirc)
acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
acBlkTbl.Add(acBlkTblRec)
acTrans.AddNewlyCreatedDBObject(acBlkTblRec, True)
End Using
blkRecId = acBlkTblRec.Id
End Using
Else
blkRecId = acBlkTbl("CircleBlock")
End If
' Insert the block into the current space
If blkRecId <> ObjectId.Null Then
Using acBlkRef As New BlockReference(New Point3d(0, 0, 0), blkRecId)
Dim acCurSpaceBlkTblRec As BlockTableRecord
acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
acCurSpaceBlkTblRec.AppendEntity(acBlkRef)
acTrans.AddNewlyCreatedDBObject(acBlkRef, True)
Using dbObjCol As New DBObjectCollection
acBlkRef.Explode(dbObjCol)
For Each dbObj As DBObject In dbObjCol
Dim acEnt As Entity = dbObj
acCurSpaceBlkTblRec.AppendEntity(acEnt)
acTrans.AddNewlyCreatedDBObject(dbObj, True)
acEnt = acTrans.GetObject(dbObj.ObjectId, OpenMode.ForWrite)
acEnt.ColorIndex = 1
MsgBox("Exploded Object: " & acEnt.GetRXClass().DxfName)
Next
End Using
End Using
End If
' Save the new object to the database
acTrans.Commit()
' Dispose of the transaction
End Using
[CommandMethod("ExplodingABlock")]
public void ExplodingABlock()
// Get the current database and start a transaction
Database acCurDb;
acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
BlockTable acBlkTbl;
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
ObjectId blkRecId = ObjectId.Null;
if (!acBlkTbl.Has("CircleBlock"))
using (BlockTableRecord acBlkTblRec = new BlockTableRecord())
acBlkTblRec.Name = "CircleBlock";
// Set the insertion point for the block
acBlkTblRec.Origin = new Point3d(0, 0, 0);
// Add a circle to the block
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(0, 0, 0);
acCirc.Radius = 2;
acBlkTblRec.AppendEntity(acCirc);
acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite);
acBlkTbl.Add(acBlkTblRec);
acTrans.AddNewlyCreatedDBObject(acBlkTblRec, true);
blkRecId = acBlkTblRec.Id;
else
blkRecId = acBlkTbl["CircleBlock"];
// Insert the block into the current space
if (blkRecId != ObjectId.Null)
using (BlockReference acBlkRef = new BlockReference(new Point3d(0, 0, 0), blkRecId))
BlockTableRecord acCurSpaceBlkTblRec;
acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
acCurSpaceBlkTblRec.AppendEntity(acBlkRef);
acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
using (DBObjectCollection dbObjCol = new DBObjectCollection())
acBlkRef.Explode(dbObjCol);
foreach (DBObject dbObj in dbObjCol)
Entity acEnt = dbObj as Entity;
acCurSpaceBlkTblRec.AppendEntity(acEnt);
acTrans.AddNewlyCreatedDBObject(dbObj, true);
acEnt = acTrans.GetObject(dbObj.ObjectId, OpenMode.ForWrite) as Entity;
acEnt.ColorIndex = 1;
Application.ShowAlertDialog("Exploded Object: " + acEnt.GetRXClass().DxfName);
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub ExplodingABlock()
' Define the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0
insertionPnt(1) = 0
insertionPnt(2) = 0
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0
center(1) = 0
center(2) = 0
rad = 2
Set circleObj = blockObj.AddCircle(center, rad)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 0
insertionPnt(1) = 0
insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1, 1, 1, 0)
' Explode the block reference
Dim explodedObjects As Variant
explodedObjects = blockRefObj.Explode
' Loop through the exploded objects
Dim I As Integer
For I = 0 To UBound(explodedObjects)
explodedObjects(I).Color = acRed
explodedObjects(I).Update
MsgBox "Exploded Object " & I & ": " & explodedObjects(I).ObjectName
Next
父主题: |
GMT+8, 2026-11-12 12:33
