在 3D 中旋转 (.NET)
使用对象的方法和矩阵的方法,可以围绕指定点以 2D 方式旋转对象。2D 对象的旋转方向是围绕 Z 轴的。对于 3D 对象,旋转轴不限于 Z 轴。使用该方法而不是将 Z 轴用于旋转轴时,请指定特定的 3D 矢量。TransformByRotationRotation ![]() 创建一个 3D 盒子并绕轴旋转它本示例创建一个 3D 框。然后,它定义要旋转的轴,最后将盒子绕轴旋转 30 度。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("Rotate_3DBox")> _
Public Sub Rotate_3DBox()
'' Get the current document and database, and start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a 3D solid box
Using acSol3D As Solid3d = New Solid3d()
acSol3D.CreateBox(5, 7, 10)
'' Position the center of the 3D solid at (5,5,0)
acSol3D.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
Point3d.Origin))
Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d
'' Rotate the 3D solid 30 degrees around the axis that is
'' defined by the points (-3,4,0) and (-3,-4,0)
Dim vRot As Vector3d = New Point3d(-3, 4, 0). _
GetVectorTo(New Point3d(-3, -4, 0))
acSol3D.TransformBy(Matrix3d.Rotation(0.5236, _
vRot, _
New Point3d(-3, 4, 0)))
acBlkTblRec.AppendEntity(acSol3D)
acTrans.AddNewlyCreatedDBObject(acSol3D, True)
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("Rotate_3DBox")]
public static void Rotate_3DBox()
// Get the current document and database, and start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a 3D solid box
using (Solid3d acSol3D = new Solid3d())
acSol3D.CreateBox(5, 7, 10);
// Position the center of the 3D solid at (5,5,0)
acSol3D.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
Point3d.Origin));
Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
// Rotate the 3D solid 30 degrees around the axis that is
// defined by the points (-3,4,0) and (-3,-4,0)
Vector3d vRot = new Point3d(-3, 4, 0).
GetVectorTo(new Point3d(-3, -4, 0));
vRot,
new Point3d(-3, 4, 0)));
acBlkTblRec.AppendEntity(acSol3D);
acTrans.AddNewlyCreatedDBObject(acSol3D, true);
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub Rotate_3DBox()
Dim boxObj As Acad3DSolid
Dim length As Double
Dim width As Double
Dim height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5: center(1) = 5: center(2) = 0
length = 5
width = 7
height = 10
' Create the box object in model space
Set boxObj = ThisDrawing.ModelSpace. _
AddBox(center, length, width, height)
' Define the rotation axis with two points
Dim rotatePt1(0 To 2) As Double
Dim rotatePt2(0 To 2) As Double
Dim rotateAngle As Double
rotatePt1(0) = -3: rotatePt1(1) = 4: rotatePt1(2) = 0
rotatePt2(0) = -3: rotatePt2(1) = -4: rotatePt2(2) = 0
rotateAngle = 30
rotateAngle = rotateAngle * 3.141592 / 180#
' Rotate the box
boxObj.Rotate3D rotatePt1, rotatePt2, rotateAngle
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-23 01:15
