创建多面网格 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 622| 评论: 0|原作者: admin|来自: AutoCAD
创建多面网格 (.NET)
多面网格表示由能够具有多个顶点的面定义的对象的表面。创建多面网格类似于创建矩形网格。您可以通过创建对象的实例来创建多面网格。对象的构造函数不接受任何参数。要将顶点添加到多面网格,请创建一个顶点并使用该方法将其添加到对象中。PolyFaceMeshPolyFaceMeshPolyFaceMeshVertexPolyFaceMeshAppendVertex
创建多面网格时,可以将特定边设置为不可见,将其指定给图层,或为其赋予颜色。若要使边不可见,请创建一个实例并设置哪些边应该是不可见的,然后使用该方法将对象追加到对象。FaceRecordFaceRecordPolyFaceMeshAppendFaceRecord
创建多面网格
本示例创建一个对象并更改活动视口的查看方向,以显示网格的三维性质。PolyfaceMesh
VB.NET
<CommandMethod("CreatePolyfaceMesh")> _
Public Sub CreatePolyfaceMesh()
    '' Get the current document and database, and start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a polyface mesh
        Using acPFaceMesh As PolyFaceMesh = New PolyFaceMesh()
            acBlkTblRec.AppendEntity(acPFaceMesh)
            acTrans.AddNewlyCreatedDBObject(acPFaceMesh, True)
            '' Before adding vertexes, the polyline must be in the drawing
            Dim acPts3dPFMesh As Point3dCollection = New Point3dCollection()
            acPts3dPFMesh.Add(New Point3d(4, 7, 0))
            acPts3dPFMesh.Add(New Point3d(5, 7, 0))
            acPts3dPFMesh.Add(New Point3d(6, 7, 0))
            acPts3dPFMesh.Add(New Point3d(4, 6, 0))
            acPts3dPFMesh.Add(New Point3d(5, 6, 0))
            acPts3dPFMesh.Add(New Point3d(6, 6, 1))
            For Each acPt3d As Point3d In acPts3dPFMesh
                Dim acPMeshVer As PolyFaceMeshVertex = New PolyFaceMeshVertex(acPt3d)
                acPFaceMesh.AppendVertex(acPMeshVer)
                acTrans.AddNewlyCreatedDBObject(acPMeshVer, True)
            Next
            Using acFaceRec1 As FaceRecord = New FaceRecord(1, 2, 5, 4)
                acPFaceMesh.AppendFaceRecord(acFaceRec1)
                acTrans.AddNewlyCreatedDBObject(acFaceRec1, True)
            End Using
            Using acFaceRec2 As FaceRecord = New FaceRecord(2, 3, 6, 5)
                acPFaceMesh.AppendFaceRecord(acFaceRec2)
                acTrans.AddNewlyCreatedDBObject(acFaceRec2, True)
            End Using
        End Using
        '' Open the active viewport
        Dim acVportTblRec As ViewportTableRecord
        acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, _
                                          OpenMode.ForWrite)
        '' Rotate the view direction of the current viewport
        acVportTblRec.ViewDirection = New Vector3d(-1, -1, 1)
        acDoc.Editor.UpdateTiledViewportsFromDatabase()
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreatePolyfaceMesh")]
public static void CreatePolyfaceMesh()
    // Get the current document and database, and start a transaction
        // Open the Block table record for read
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a polyface mesh
        using (PolyFaceMesh acPFaceMesh = new PolyFaceMesh())
            acBlkTblRec.AppendEntity(acPFaceMesh);
            acTrans.AddNewlyCreatedDBObject(acPFaceMesh, true);
            // Before adding vertexes, the polyline must be in the drawing
            Point3dCollection acPts3dPFMesh = new Point3dCollection();
            acPts3dPFMesh.Add(new Point3d(4, 7, 0));
            acPts3dPFMesh.Add(new Point3d(5, 7, 0));
            acPts3dPFMesh.Add(new Point3d(6, 7, 0));
            acPts3dPFMesh.Add(new Point3d(4, 6, 0));
            acPts3dPFMesh.Add(new Point3d(5, 6, 0));
            acPts3dPFMesh.Add(new Point3d(6, 6, 1));
            foreach (Point3d acPt3d in acPts3dPFMesh)
                PolyFaceMeshVertex acPMeshVer = new PolyFaceMeshVertex(acPt3d);
                acPFaceMesh.AppendVertex(acPMeshVer);
                acTrans.AddNewlyCreatedDBObject(acPMeshVer, true);
            using (FaceRecord acFaceRec1 = new FaceRecord(1, 2, 5, 4))
                acPFaceMesh.AppendFaceRecord(acFaceRec1);
                acTrans.AddNewlyCreatedDBObject(acFaceRec1, true);
            using (FaceRecord acFaceRec2 = new FaceRecord(2, 3, 6, 5))
                acPFaceMesh.AppendFaceRecord(acFaceRec2);
                acTrans.AddNewlyCreatedDBObject(acFaceRec2, true);
        // Open the active viewport
        ViewportTableRecord acVportTblRec;
                                            OpenMode.ForWrite) as ViewportTableRecord;
        // Rotate the view direction of the current viewport
        acVportTblRec.ViewDirection = new Vector3d(-1, -1, 1);
        acDoc.Editor.UpdateTiledViewportsFromDatabase();
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    'Define the mesh vertices
    Dim vertex(0 To 17) As Double
    vertex(0) = 4: vertex(1) = 7: vertex(2) = 0
    vertex(3) = 5: vertex(4) = 7: vertex(5) = 0
    vertex(6) = 6: vertex(7) = 7: vertex(8) = 0
    vertex(9) = 4: vertex(10) = 6: vertex(11) = 0
    vertex(12) = 5: vertex(13) = 6: vertex(14) = 0
    vertex(15) = 6: vertex(16) = 6: vertex(17) = 1
    ' Define the face list
    Dim FaceList(0 To 7) As Integer
    FaceList(0) = 1
    FaceList(1) = 2
    FaceList(2) = 5
    FaceList(3) = 4
    FaceList(4) = 2
    FaceList(5) = 3
    FaceList(6) = 6
    FaceList(7) = 5
    ' Create the polyface mesh
    Dim polyfaceMeshObj As AcadPolyfaceMesh
    Set polyfaceMeshObj = ThisDrawing.ModelSpace. _
                              AddPolyfaceMesh(vertex, FaceList)
    ' Change the viewing direction of the viewport to
    ' better see the polyface mesh
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1
    NewDirection(1) = -1
    NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
GMT+8, 2026-10-24 07:05
