分配字体 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 681| 评论: 0|原作者: admin|来自: AutoCAD
分配字体 (.NET)
字体定义构成每个字符集的文本字符的形状。一种字体可以由多种样式使用。使用该属性设置文本样式的字体文件。可以将 TrueType 或 AutoCAD 编译的 SHX 字体指定为文本样式。FileName
设置文本字体
下面的示例使用活动文本样式的属性获取当前字体值,然后将字体的字体更改为“PlayBill”。若要查看更改字体的效果,请在运行示例之前向当前图形添加一些多行或单行文本。请注意,如果您的系统上没有 PlayBill 字体,则需要替换您拥有的字体才能使此示例正常工作。Font
VB.NET
<CommandMethod("UpdateTextFont")> _
Public Sub UpdateTextFont()
    '' Start a transaction
        '' Open the current text style for write
        Dim acTextStyleTblRec As TextStyleTableRecord
        acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, _
                                              OpenMode.ForWrite)
        '' Get the current font settings
        Dim acFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
        acFont = acTextStyleTblRec.Font
        '' Update the text style's typeface with "PlayBill"
        Dim acNewFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
        acNewFont = New  _
          Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("PlayBill", _
                                                            acFont.Bold, _
                                                            acFont.Italic, _
                                                            acFont.CharacterSet, _
                                                            acFont.PitchAndFamily)
        acTextStyleTblRec.Font = acNewFont
        acDoc.Editor.Regen()
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("UpdateTextFont")]
public static void UpdateTextFont()
    // Start a transaction
        // Open the current text style for write
        TextStyleTableRecord acTextStyleTblRec;
                                              OpenMode.ForWrite) as TextStyleTableRecord;
        // Get the current font settings
        Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acFont;
        acFont = acTextStyleTblRec.Font;
        // Update the text style's typeface with "PlayBill"
        Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acNewFont;
        acNewFont = new
                                                            acFont.Bold,
                                                            acFont.Italic,
                                                            acFont.PitchAndFamily);
        acTextStyleTblRec.Font = acNewFont;
        acDoc.Editor.Regen();
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    MsgBox ("Look at the text now...")
    Dim typeFace As String
    Dim SavetypeFace As String
    Dim Bold As Boolean
    Dim Italic As Boolean
    Dim charSet As Long
    Dim PitchandFamily As Long
    ' Get the current settings to fill in the
    ' default values for the SetFont method
    ThisDrawing.ActiveTextStyle.GetFont typeFace, _
                  Bold, Italic, charSet, PitchandFamily
    ' Change the typeface for the font
    SavetypeFace = typeFace
    typeFace = "PlayBill"
    ThisDrawing.ActiveTextStyle.SetFont typeFace, _
    ThisDrawing.Regen acActiveViewport
GMT+8, 2026-11-14 14:47
