删除图层状态 (.NET)
该方法从图形中移除保存的图层状态。以下代码将删除以 ColorLinetype 名称保存的图层状态。DeleteLayerState VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("RemoveLayerState")> _
Public Sub RemoveLayerState()
'' Get the current document
Dim acLyrStMan As LayerStateManager
acLyrStMan = acDoc.Database.LayerStateManager
Dim sLyrStName As String = "ColorLinetype"
If acLyrStMan.HasLayerState(sLyrStName) = True Then
acLyrStMan.DeleteLayerState(sLyrStName)
End If
[CommandMethod("RemoveLayerState")]
public static void RemoveLayerState()
// Get the current document
LayerStateManager acLyrStMan;
acLyrStMan = acDoc.Database.LayerStateManager;
string sLyrStName = "ColorLinetype";
if (acLyrStMan.HasLayerState(sLyrStName) == true)
acLyrStMan.DeleteLayerState(sLyrStName);
VBA/ActiveX 代码参考Sub RemoveLayerState()
Dim oLSM As AcadLayerStateManager
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager.23")
oLSM.SetDatabase ThisDrawing.Database
oLSM.Delete "ColorLinetype"
GMT+8, 2026-11-14 18:17
