重命名图层状态 (.NET)
该方法在图形中将保存的图层状态从一个名称重命名为另一个名称。以下代码将 ColorLinetype 图层设置重命名为 OldColorLinetype。RenameLayerState VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("RenameLayerState")> _
Public Sub RenameLayerState()
'' Get the current document
Dim acLyrStMan As LayerStateManager
acLyrStMan = acDoc.Database.LayerStateManager
Dim sLyrStName As String = "ColorLinetype"
Dim sLyrStNewName As String = "OldColorLinetype"
If acLyrStMan.HasLayerState(sLyrStName) = True And _
acLyrStMan.HasLayerState(sLyrStNewName) = False Then
acLyrStMan.RenameLayerState(sLyrStName, sLyrStNewName)
End If
[CommandMethod("RenameLayerState")]
public static void RenameLayerState()
// Get the current document
LayerStateManager acLyrStMan;
acLyrStMan = acDoc.Database.LayerStateManager;
string sLyrStName = "ColorLinetype";
string sLyrStNewName = "OldColorLinetype";
if (acLyrStMan.HasLayerState(sLyrStName) == true &&
acLyrStMan.HasLayerState(sLyrStNewName) == false)
acLyrStMan.RenameLayerState(sLyrStName, sLyrStNewName);
VBA/ActiveX 代码参考Sub RenameLayerState()
Dim oLSM As AcadLayerStateManager
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager.23")
oLSM.SetDatabase ThisDrawing.Database
oLSM.Rename "ColorLinetype", "OldColorLinetype"
GMT+8, 2026-11-13 13:28
