为对象分配线型 (.NET)
以下示例创建一个圆圈,并为其分配“中心”线型。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SetObjectLinetype")> _
Public Sub SetObjectLinetype()
'' Start a transaction
'' Open the Linetype table for read
Dim acLineTypTbl As LinetypeTable
acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _
OpenMode.ForRead)
Dim sLineTypName As String = "Center"
If acLineTypTbl.Has(sLineTypName) = False Then
acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin")
End If
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle object
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 1
acCirc.Linetype = sLineTypName
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("SetObjectLinetype")]
public static void SetObjectLinetype()
// Start a transaction
// Open the Linetype table for read
LinetypeTable acLineTypTbl;
OpenMode.ForRead) as LinetypeTable;
string sLineTypName = "Center";
if (acLineTypTbl.Has(sLineTypName) == false)
acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin");
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle object
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 1;
acCirc.Linetype = sLineTypName;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub SetObjectLinetype()
' Load the Center linetype
Dim linetypeName As String
linetypeName = "Center"
On Error Resume Next
ThisDrawing.Linetypes.Load linetypeName, "acad.lin"
' Define the center point of the circle
Dim centerPt(0 To 2) As Double
centerPt(0) = 0: centerPt(1) = 3: centerPt(2) = 0
' Create a new circle and assign it the ACI value of 4
Dim circleObj As AcadCircle
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, 1)
circleObj.Linetype = linetypeName
circleObj.Update
相关概念父主题: |
GMT+8, 2026-11-12 12:22
