擦除图层 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 656| 评论: 0|原作者: admin|来自: AutoCAD
擦除图层 (.NET)
您可以在绘图会话期间随时拭除图层。无法拭除当前图层、图层 0、与外部参照相关的图层或包含对象的图层。
要擦除图层,请使用该方法。建议使用 Purge 函数来验证该图层是否可以被清除,同时验证它不是图层 0、Defpoints 或当前图层。Erase
注意:块定义引用的图层以及名为 DEFPOINTS 的特殊图层即使不包含可见对象,也无法删除。
VB.NET
<CommandMethod("EraseLayer")> _
Public Sub EraseLayer()
    '' Start a transaction
        '' Open the Layer table for read
        Dim acLyrTbl As LayerTable
        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                     OpenMode.ForRead)
        Dim sLayerName As String = "ABC"
        If acLyrTbl.Has(sLayerName) = True Then
            '' Check to see if it is safe to erase layer
            Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
            acObjIdColl.Add(acLyrTbl(sLayerName))
            acCurDb.Purge(acObjIdColl)
            If acObjIdColl.Count > 0 Then
                Dim acLyrTblRec As LayerTableRecord
                acLyrTblRec = acTrans.GetObject(acObjIdColl(0), OpenMode.ForWrite)
                Try
                    '' Erase the unreferenced layer
                    acLyrTblRec.Erase(True)
                    '' Save the changes and dispose of the transaction
                    acTrans.Commit()
                Catch Ex As Autodesk.AutoCAD.Runtime.Exception
                    '' Layer could not be deleted
                    Application.ShowAlertDialog("Error:\n" + Ex.Message)
                End Try
            End If
        End If
    End Using
C#
[CommandMethod("EraseLayer")]
public static void EraseLayer()
    // Start a transaction
        // Open the Layer table for read
        LayerTable acLyrTbl;
                                        OpenMode.ForRead) as LayerTable;
        string sLayerName = "ABC";
        if (acLyrTbl.Has(sLayerName) == true)
            // Check to see if it is safe to erase layer
            ObjectIdCollection acObjIdColl = new ObjectIdCollection();
            acObjIdColl.Add(acLyrTbl[sLayerName]);
            acCurDb.Purge(acObjIdColl);
            if (acObjIdColl.Count > 0)
                LayerTableRecord acLyrTblRec;
                acLyrTblRec = acTrans.GetObject(acObjIdColl[0],
                                                OpenMode.ForWrite) as LayerTableRecord;
                try
                    // Erase the unreferenced layer
                    acLyrTblRec.Erase(true);
                    // Save the changes and dispose of the transaction
                    acTrans.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception Ex)
                    // Layer could not be deleted
                    Application.ShowAlertDialog("Error:\n" + Ex.Message);
VBA/ActiveX 代码参考
Sub EraseLayer()
    On Error Resume Next
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers("ABC")
    layerObj.Delete
GMT+8, 2026-11-13 13:17
