锁定和解锁层 (.NET)
您无法编辑锁定图层上的对象;但是,如果该层打开并解冻,它们仍然可见。您可以使锁定层成为当前图层,并且可以向其添加对象。您可以冻结和关闭锁定的图层,并更改其关联的颜色和线型。 使用该属性锁定或解锁图层。如果输入值 ,则图层将被锁定。如果输入值 ,则图层将解锁。IsLockedTRUEFALSE 锁定图层本示例创建一个名为“ABC”的新图层,然后锁定该图层。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("LockLayer")> _
Public Sub LockLayer()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerName As String = "ABC"
If acLyrTbl.Has(sLayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' Assign the layer a name
acLyrTblRec.Name = sLayerName
'' Lock the layer
acLyrTblRec.IsLocked = True
'' Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
Else
Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
OpenMode.ForWrite)
'' Lock the layer
End If
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("LockLayer")]
public static void LockLayer()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerName = "ABC";
if (acLyrTbl.Has(sLayerName) == false)
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
// Assign the layer a name
acLyrTblRec.Name = sLayerName;
// Lock the layer
acLyrTblRec.IsLocked = true;
// Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
OpenMode.ForWrite) as LayerTableRecord;
// Lock the layer
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub LockLayer()
' Create a new layer called "ABC"
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("ABC")
' Lock layer "ABC"
layerObj.Lock = True
相关概念父主题: |
GMT+8, 2026-11-13 13:38
