打开和关闭图层 (.NET)
关闭的图层随图形一起再生,但不显示或打印。通过关闭图层,可以避免每次解冻图层时重新生成图形。当您打开已关闭的图层时,AutoCAD 会重新绘制该图层上的对象。 在对象上使用表示要打开或关闭的图层的属性。如果输入值 ,则图层将关闭。如果输入值 ,则图层处于打开状态。IsOffLayerTableRecordTRUEFALSE 关闭图层本示例创建一个新图层并将其关闭,然后向该图层添加一个圆圈,使该圆圈不再可见。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("TurnLayerOff")> _
Public Sub TurnLayerOff()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerName As String = "ABC"
If acLyrTbl.Has(sLayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' Assign the layer a name
acLyrTblRec.Name = sLayerName
'' Turn the layer off
acLyrTblRec.IsOff = True
'' Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
Else
Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
OpenMode.ForWrite)
End If
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle object
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 1
acCirc.Layer = sLayerName
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("TurnLayerOff")]
public static void TurnLayerOff()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerName = "ABC";
if (acLyrTbl.Has(sLayerName) == false)
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
// Assign the layer a name
acLyrTblRec.Name = sLayerName;
// Turn the layer off
acLyrTblRec.IsOff = true;
// Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
OpenMode.ForWrite) as LayerTableRecord;
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle object
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 1;
acCirc.Layer = sLayerName;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub TurnLayerOff()
' Create a new layer called "ABC"
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("ABC")
' Turn off layer "ABC"
layerObj.LayerOn = False
' Create a circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2: center(1) = 2: center(2) = 0
radius = 1
Set circleObj = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
' Assign the circle to the "ABC" layer
circleObj.Layer = "ABC"
circleObj.Update
ThisDrawing.Regen acActiveViewport
相关概念父主题: |
GMT+8, 2026-11-13 13:36
