编辑填充图案 (.NET)
您可以更改现有填充图案的角度或间距,也可以将其替换为实体填充、渐变填充或 AutoCAD 提供的预定义图案之一。功能区上的“边界填充线”(Boundary Hatch) 对话框或“阵列库”(Pattern gallery) 中的“阵列”(Pattern) 选项将显示这些阵列的列表。为了减小文件大小,在图形中将填充定义为单个图形对象。 使用以下属性和方法来编辑填充图案:
更改图案填充的图案间距本示例创建一个填充。然后,它将填充的当前图案间距增加 2。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("EditHatchPatternScale")> _
Public Sub EditHatchPatternScale()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle object for the boundary of the hatch
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(5, 3, 0)
acCirc.Radius = 3
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
'' Adds the arc and line to an object id collection
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
acObjIdColl.Add(acCirc.ObjectId)
'' Create the hatch object and append it to the block table record
Using acHatch As Hatch = New Hatch()
acBlkTblRec.AppendEntity(acHatch)
acTrans.AddNewlyCreatedDBObject(acHatch, True)
'' Set the properties of the hatch object
'' Associative must be set after the hatch object is appended to the
'' block table record and before AppendLoop
acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
acHatch.Associative = True
acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl)
'' Evaluate the hatch
acHatch.EvaluateHatch(True)
'' Increase the pattern scale by 2 and re-evaluate the hatch
acHatch.PatternScale = acHatch.PatternScale + 2
acHatch.SetHatchPattern(acHatch.PatternType, acHatch.PatternName)
End Using
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("EditHatchPatternScale")]
public static void EditHatchPatternScale()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle object for the boundary of the hatch
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(5, 3, 0);
acCirc.Radius = 3;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Adds the arc and line to an object id collection
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
acObjIdColl.Add(acCirc.ObjectId);
// Create the hatch object and append it to the block table record
using (Hatch acHatch = new Hatch())
acBlkTblRec.AppendEntity(acHatch);
acTrans.AddNewlyCreatedDBObject(acHatch, true);
// Set the properties of the hatch object
// Associative must be set after the hatch object is appended to the
// block table record and before AppendLoop
acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
acHatch.Associative = true;
acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
// Evaluate the hatch
acHatch.EvaluateHatch(true);
// Increase the pattern scale by 2 and re-evaluate the hatch
acHatch.PatternScale = acHatch.PatternScale + 2;
acHatch.SetHatchPattern(acHatch.PatternType, acHatch.PatternName);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub EditHatchPatternScale()
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace. _
AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
Dim outerLoop(0 To 0) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 5
center(1) = 3
center(2) = 0
radius = 3
Set outerLoop(0) = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
hatchObj.AppendOuterLoop (outerLoop)
hatchObj.Evaluate
' Change the scale of the hatch pattern by
' adding 2 to the current scale
hatchObj.patternScale = hatchObj.patternScale + 2
hatchObj.Evaluate
ThisDrawing.Regen True
相关概念父主题: |
GMT+8, 2026-11-13 13:39
