缩放对象 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 817| 评论: 0|原作者: admin|来自: AutoCAD
缩放对象 (.NET)
通过基于当前绘图单位指定基点和比例因子来缩放对象。可以缩放所有图形对象以及属性参照对象。
若要缩放对象,请使用转换矩阵的函数。此函数需要对象比例因子的数值和缩放操作基点的对象。该函数在 X、Y 和 Z 方向上平均缩放对象。对象的尺寸乘以比例因子。大于 1 的比例因子将放大对象。介于 0 和 1 之间的比例因子会减少对象。ScalingPoint3dScaling
注意:如果需要非均匀缩放对象,则需要使用适当的数据数组初始化转换矩阵,然后使用对象的方法。TransformBy
缩放折线
本示例创建闭合的轻量级折线,然后从基点 (4,4.25,0) 按折线比例缩放 0.5。
VB.NET
<CommandMethod("ScaleObject")> _
Public Sub ScaleObject()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a lightweight polyline
        Using acPoly As Polyline = New Polyline()
            acPoly.AddVertexAt(0, New Point2d(1, 2), 0, 0, 0)
            acPoly.AddVertexAt(1, New Point2d(1, 3), 0, 0, 0)
            acPoly.AddVertexAt(2, New Point2d(2, 3), 0, 0, 0)
            acPoly.AddVertexAt(3, New Point2d(3, 3), 0, 0, 0)
            acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0)
            acPoly.AddVertexAt(5, New Point2d(4, 2), 0, 0, 0)
            '' Close the polyline
            acPoly.Closed = True
            '' Reduce the object by a factor of 0.5
            '' using a base point of (4,4.25,0)
            acPoly.TransformBy(Matrix3d.Scaling(0.5, New Point3d(4, 4.25, 0)))
            acBlkTblRec.AppendEntity(acPoly)
            acTrans.AddNewlyCreatedDBObject(acPoly, True)
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("ScaleObject")]
public static void ScaleObject()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a lightweight polyline
        using (Polyline acPoly = new Polyline())
            acPoly.AddVertexAt(0, new Point2d(1, 2), 0, 0, 0);
            acPoly.AddVertexAt(1, new Point2d(1, 3), 0, 0, 0);
            acPoly.AddVertexAt(2, new Point2d(2, 3), 0, 0, 0);
            acPoly.AddVertexAt(3, new Point2d(3, 3), 0, 0, 0);
            acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0);
            acPoly.AddVertexAt(5, new Point2d(4, 2), 0, 0, 0);
            // Close the polyline
            acPoly.Closed = true;
            // Reduce the object by a factor of 0.5
            // using a base point of (4,4.25,0)
            acPoly.TransformBy(Matrix3d.Scaling(0.5, new Point3d(4, 4.25, 0)));
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub ScaleObject()
    ' Create the polyline
    Dim points(0 To 11) As Double
    points(0) = 1: points(1) = 2
    points(2) = 1: points(3) = 3
    points(4) = 2: points(5) = 3
    points(6) = 3: points(7) = 3
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 2
    Set plineObj = ThisDrawing.ModelSpace. _
                                 AddLightWeightPolyline(points)
    plineObj.Closed = True
    ZoomAll
    ' Define the scale
    Dim basePoint(0 To 2) As Double
    Dim scalefactor As Double
    basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
    scalefactor = 0.5
    ' Scale the polyline
    plineObj.ScaleEntity basePoint, scalefactor
    plineObj.Update
GMT+8, 2026-11-12 12:33
