移动对象 (.NET)
可以沿指定矢量移动所有图形对象和属性参照对象。 若要移动对象,请使用变换矩阵的函数。此函数需要一个对象作为输入。如果不知道所需的向量,可以创建一个对象,然后使用该方法返回两点之间的向量。位移矢量指示给定对象要移动多远以及向哪个方向移动。DisplacementVector3dPoint3dGetVectorTo ![]() 沿矢量移动圆圈本示例创建一个圆,然后沿 X 轴移动该圆两个单位。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("MoveObject")> _
Public Sub MoveObject()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle that is at 2,2 with a radius of 0.5
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 0.5
'' Create a matrix and move the circle using a vector from (0,0,0) to (2,0,0)
Dim acPt3d As Point3d = New Point3d(0, 0, 0)
Dim acVec3d As Vector3d = acPt3d.GetVectorTo(New Point3d(2, 0, 0))
acCirc.TransformBy(Matrix3d.Displacement(acVec3d))
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("MoveObject")]
public static void MoveObject()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle that is at 2,2 with a radius of 0.5
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 0.5;
// Create a matrix and move the circle using a vector from (0,0,0) to (2,0,0)
Point3d acPt3d = new Point3d(0, 0, 0);
Vector3d acVec3d = acPt3d.GetVectorTo(new Point3d(2, 0, 0));
acCirc.TransformBy(Matrix3d.Displacement(acVec3d));
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub MoveObject()
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
ZoomAll
' Define the points that make up the move vector.
' The move vector will move the circle 2 units
' along the x axis.
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 2: point2(1) = 0: point2(2) = 0
' Move the circle
circleObj.Move point1, point2
circleObj.Update
相关概念父主题: |
GMT+8, 2026-11-14 14:18
