获取 PickFirst 选择集 (.NET)
在启动命令之前选择对象时,将创建 PickFirst 选择集。为了获取 PickFirst 选择集的对象,必须满足几个条件,这些条件是:
该方法用于清除当前的 PickFirst 选择集。SetImpliedSelection 获取 Pickfirst 选择集本示例显示 PickFirst 选择集中的对象数,然后请求用户选择其他对象。在请求用户选择对象之前,将使用该方法清除当前的 PickFirst 选择集。SetImpliedSelection VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)> _
Public Sub CheckForPickfirstSelection()
'' Get the current document
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Get the PickFirst selection set
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.SelectImplied()
Dim acSSet As SelectionSet
'' If the prompt status is OK, objects were selected before
'' the command was started
If acSSPrompt.Status = PromptStatus.OK Then
acSSet = acSSPrompt.Value
Application.ShowAlertDialog("Number of objects in Pickfirst selection: " & _
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects in Pickfirst selection: 0")
End If
'' Clear the PickFirst selection set
Dim idarrayEmpty() As ObjectId
acDocEd.SetImpliedSelection(idarrayEmpty)
'' Request for objects to be selected in the drawing area
acSSPrompt = acDocEd.GetSelection()
Application.ShowAlertDialog("Number of objects selected: " & _
Else
Application.ShowAlertDialog("Number of objects selected: 0")
End If
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)]
public static void CheckForPickfirstSelection()
// Get the current document
Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
// Get the PickFirst selection set
PromptSelectionResult acSSPrompt;
acSSPrompt = acDocEd.SelectImplied();
SelectionSet acSSet;
// If the prompt status is OK, objects were selected before
// the command was started
if (acSSPrompt.Status == PromptStatus.OK)
acSSet = acSSPrompt.Value;
Application.ShowAlertDialog("Number of objects in Pickfirst selection: " +
acSSet.Count.ToString());
else
Application.ShowAlertDialog("Number of objects in Pickfirst selection: 0");
// Clear the PickFirst selection set
ObjectId[] idarrayEmpty = new ObjectId[0];
acDocEd.SetImpliedSelection(idarrayEmpty);
// Request for objects to be selected in the drawing area
acSSPrompt = acDocEd.GetSelection();
Application.ShowAlertDialog("Number of objects selected: " +
else
Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考Sub CheckForPickfirstSelection()
' Get the Pickfirst selection set
Dim acSSet As AcadSelectionSet
Set acSSet = ThisDrawing.PickfirstSelectionSet
' Display the number of selected objects
MsgBox "Number of objects in Pickfirst selection set: " & acSSet.Count
' Create a new selection set
Dim acSSetUser As AcadSelectionSet
Set acSSetUser = ThisDrawing.SelectionSets.Add("User")
' Select objects in the drawing
acSSetUser.SelectOnScreen
MsgBox "Number of objects selected: " & acSSetUser.Count
' Remove the new named selection set
acSSetUser.Delete
相关概念父主题: |
GMT+8, 2026-11-12 12:20
