调整对齐和网格对齐方式 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 946| 评论: 0|原作者: admin|来自: AutoCAD
调整对齐和网格对齐方式 (.NET)
网格是测量距离的视觉指南,而捕捉模式用于限制光标移动。除了设置网格和捕捉模式的间距外,还可以调整所用捕捉的旋转和类型。
如果需要沿特定对齐方式或角度绘制,可以旋转捕捉角度。捕捉角度旋转的中心点是捕捉基点。
注意:更改活动视口的对齐和网格设置后,应使用 Editor 对象的方法更新绘图区域的显示。UpdateTiledViewportsFromDatabase
捕捉和格网不会影响通过 AutoCAD .NET API 指定的点,但如果用户被要求使用 或 等方法输入输入,则会影响用户在绘图区域中指定的点。GetPointGetEntity
更改网格和捕捉设置
本示例将捕捉基点更改为 (1,1),捕捉旋转角度更改为 30 度。网格打开,间距调整,以便可以看到更改。
VB.NET
<CommandMethod("ChangeGridAndSnap")> _
Public Sub ChangeGridAndSnap()
  '' Get the current database
  '' Start a transaction
      '' Open the active viewport
      Dim acVportTblRec As ViewportTableRecord
      acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, _
                                        OpenMode.ForWrite)
      '' Turn on the grid for the active viewport
      acVportTblRec.GridEnabled = True
      '' Adjust the spacing of the grid to 1, 1
      acVportTblRec.GridIncrements = New Point2d(1, 1)
      '' Turn on the snap mode for the active viewport
      acVportTblRec.SnapEnabled = True
      '' Adjust the snap spacing to 0.5, 0.5
      acVportTblRec.SnapIncrements = New Point2d(0.5, 0.5)
      '' Change the snap base point to 1, 1
      acVportTblRec.SnapBase = New Point2d(1, 1)
      '' Change the snap rotation angle to 30 degrees (0.524 radians)
      acVportTblRec.SnapAngle = 0.524
      '' Update the display of the tiled viewport
      acDoc.Editor.UpdateTiledViewportsFromDatabase()
      '' Commit the changes and dispose of the transaction
      acTrans.Commit()
  End Using
C#
[CommandMethod("ChangeGridAndSnap")]
public static void ChangeGridAndSnap()
  // Get the current database
  // Start a transaction
      // Open the active viewport
      ViewportTableRecord acVportTblRec;
                                        OpenMode.ForWrite) as ViewportTableRecord;
      // Turn on the grid for the active viewport
      acVportTblRec.GridEnabled = true;
      // Adjust the spacing of the grid to 1, 1
      acVportTblRec.GridIncrements = new Point2d(1, 1);
      // Turn on the snap mode for the active viewport
      acVportTblRec.SnapEnabled = true;
      // Adjust the snap spacing to 0.5, 0.5
      acVportTblRec.SnapIncrements = new Point2d(0.5, 0.5);
      // Change the snap base point to 1, 1
      acVportTblRec.SnapBase = new Point2d(1, 1);
      // Change the snap rotation angle to 30 degrees (0.524 radians)
      acVportTblRec.SnapAngle = 0.524;
      // Update the display of the tiled viewport
      acDoc.Editor.UpdateTiledViewportsFromDatabase();
      // Commit the changes and dispose of the transaction
      acTrans.Commit();
VBA/ActiveX 代码参考
    ThisDrawing.ActiveViewport.GridOn = True
    ThisDrawing.ActiveViewport.SetGridSpacing 1, 1
    ThisDrawing.ActiveViewport.SnapOn = True
    ThisDrawing.ActiveViewport.SetSnapSpacing 0.5, 0.5
    Dim newBasePoint(0 To 1) As Double
    newBasePoint(0) = 1: newBasePoint(1) = 1
    ThisDrawing.ActiveViewport.SnapBasePoint = newBasePoint
    Dim rotationAngle As Double
    rotationAngle = 0.524
    ThisDrawing.ActiveViewport.SnapRotationAngle = rotationAngle
    ' Reset the viewport
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
GMT+8, 2026-11-13 13:35
