使平铺视口成为当前 (.NET)
2024-5-18 18:25| 发布者: admin| 查看: 844| 评论: 0|原作者: admin|来自: AutoCAD
使平铺视口成为当前 (.NET)
在当前视口中输入点并选择对象。要使视口成为当前视口,请使用 CVPORT 系统变量,并按要设置为当前的视口编号指定视口。
您可以循环访问现有视口以查找特定视口。为此,请使用该属性标识名称为“*Active”的视口表记录。Name
拆分视口,然后遍历窗口
本示例将活动视口拆分为两个水平窗口。然后,它会循环访问图形中所有平铺的视口,并显示视口名称以及每个视口的左下角和右上角。
VB.NET
<CommandMethod("SplitAndIterateModelViewports")> _
Public Sub SplitAndIterateModelViewports()
    '' Get the current database
    '' Start a transaction
        '' Open the Viewport table for write
        Dim acVportTbl As ViewportTable
        acVportTbl = acTrans.GetObject(acCurDb.ViewportTableId, _
                                       OpenMode.ForWrite)
        '' Open the active viewport for write
        Dim acVportTblRec As ViewportTableRecord
        acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, _
                                          OpenMode.ForWrite)
        Using acVportTblRecNew As ViewportTableRecord = New ViewportTableRecord()
            '' Add the new viewport to the Viewport table and the transaction
            acVportTbl.Add(acVportTblRecNew)
            acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, True)
            '' Assign the name '*Active' to the new Viewport
            acVportTblRecNew.Name = "*Active"
            '' Use the existing lower left corner for the new viewport
            acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner
            '' Get half the X of the existing upper corner
            acVportTblRecNew.UpperRightCorner = New Point2d(acVportTblRec.UpperRightCorner.X, _
                                                            acVportTblRec.LowerLeftCorner.Y + _
                                                            ((acVportTblRec.UpperRightCorner.Y - _
                                                              acVportTblRec.LowerLeftCorner.Y) / 2))
            '' Recalculate the corner of the active viewport
            acVportTblRec.LowerLeftCorner = New Point2d(acVportTblRec.LowerLeftCorner.X, _
                                                        acVportTblRecNew.UpperRightCorner.Y)
            '' Update the display with the new tiled viewports arrangement
            acDoc.Editor.UpdateTiledViewportsFromDatabase()
            '' Step through each object in the symbol table
            For Each acObjId As ObjectId In acVportTbl
                '' Open the object for read
                Dim acVportTblRecCur As ViewportTableRecord
                acVportTblRecCur = acTrans.GetObject(acObjId, _
                                                     OpenMode.ForRead)
                If (acVportTblRecCur.Name = "*Active") Then
                    Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number)
                    Application.ShowAlertDialog("Viewport: " & acVportTblRecCur.Number & _
                                                " is now active." & _
                                                vbLf & "Lower left corner: " & _
                                                acVportTblRecCur.LowerLeftCorner.X & ", " & _
                                                acVportTblRecCur.LowerLeftCorner.Y & _
                                                vbLf & "Upper right corner: " & _
                                                acVportTblRecCur.UpperRightCorner.X & ", " & _
                                                acVportTblRecCur.UpperRightCorner.Y)
                End If
            Next
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("SplitAndIterateModelViewports")]
public static void SplitAndIterateModelViewports()
    // Get the current database
    // Start a transaction
        // Open the Viewport table for write
        ViewportTable acVportTbl;
                                        OpenMode.ForWrite) as ViewportTable;
        // Open the active viewport for write
        ViewportTableRecord acVportTblRec;
                                            OpenMode.ForWrite) as ViewportTableRecord;
        using (ViewportTableRecord acVportTblRecNew = new ViewportTableRecord())
            // Add the new viewport to the Viewport table and the transaction
            acVportTbl.Add(acVportTblRecNew);
            acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, true);
            // Assign the name '*Active' to the new Viewport
            acVportTblRecNew.Name = "*Active";
            // Use the existing lower left corner for the new viewport
            acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner;
            // Get half the X of the existing upper corner
            acVportTblRecNew.UpperRightCorner = new Point2d(acVportTblRec.UpperRightCorner.X,
        acVportTblRec.LowerLeftCorner.Y) / 2));
            // Recalculate the corner of the active viewport
            acVportTblRec.LowerLeftCorner = new Point2d(acVportTblRec.LowerLeftCorner.X,
                                                        acVportTblRecNew.UpperRightCorner.Y);
            // Update the display with the new tiled viewports arrangement
            acDoc.Editor.UpdateTiledViewportsFromDatabase();
            // Step through each object in the symbol table
            foreach (ObjectId acObjId in acVportTbl)
                // Open the object for read
                ViewportTableRecord acVportTblRecCur;
                                                        OpenMode.ForRead) as ViewportTableRecord;
                if (acVportTblRecCur.Name == "*Active")
                    Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number);
                    Application.ShowAlertDialog("Viewport: " + acVportTblRecCur.Number +
                                                " is now active." +
                                                "\nLower left corner: " +
                                                acVportTblRecCur.LowerLeftCorner.X + ", " +
                                                acVportTblRecCur.LowerLeftCorner.Y +
                                                "\nUpper right corner: " +
                                                acVportTblRecCur.UpperRightCorner.X + ", " +
                                                acVportTblRecCur.UpperRightCorner.Y);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub SplitandInterateModelViewports()
    ' Get the active viewport
    Dim vportObj As AcadViewport
    Set vportObj = ThisDrawing.ActiveViewport
    ' Split the viewport into 2 windows
    vportObj.Split acViewport2Horizontal
    ' Iterate through the viewports,
    ' highlighting each viewport and displaying
    ' the upper right and lower left corners
    ' for each.
    Dim vport As AcadViewport
    Dim LLCorner As Variant
    Dim URCorner As Variant
    For Each vport In ThisDrawing.Viewports
        ThisDrawing.ActiveViewport = vport
        LLCorner = vport.LowerLeftCorner
        URCorner = vport.UpperRightCorner
        MsgBox "Viewport: " & vport.Name & " is now active." & _
               vbCrLf & "Lower left corner: " & _
               LLCorner(0) & ", " & LLCorner(1) & vbCrLf & _
               URCorner(0) & ", " & URCorner(1)
    Next vport
GMT+8, 2026-11-14 14:39
