文档窗口的位置和大小 (.NET)
使用该对象可以修改任何文档窗口的位置和大小。可以使用该属性最小化或最大化“文档”窗口,并且可以使用该属性查找“文档”窗口的当前状态。DocumentWindowStateWindowState 调整活动“文档”窗口的大小本示例使用 Location 和属性将 Document 窗口的位置和大小设置为 400 像素宽 x 400 像素高。Size VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
<CommandMethod("SizeDocumentWindow")> _
Public Sub SizeDocumentWindow()
''Size the Document window
acDoc.Window.WindowState = Window.State.Normal
'' Set the position of the Document window
Dim ptDoc As System.Windows.Point = New System.Windows.Point(0, 0)
acDoc.Window.DeviceIndependentLocation = ptdoc
'' Set the size of the Document window
Dim szDoc As System.Windows.Size = New System.Windows.Size(400, 400)
acDoc.Window.DeviceIndependentSize = szDoc
using Autodesk.AutoCAD.Windows;
[CommandMethod("SizeDocumentWindow")]
public static void SizeDocumentWindow()
//Size the Document window
// Works around what looks to be a refresh problem with the Application window
acDoc.Window.WindowState = Window.State.Normal;
// Set the position of the Document window
System.Windows.Point ptDoc = new System.Windows.Point(0, 0);
acDoc.Window.DeviceIndependentLocation = ptDoc;
// Set the size of the Document window
System.Windows.Size szDoc = new System.Windows.Size(400, 400);
acDoc.Window.DeviceIndependentSize = szDoc;
VBA/ActiveX 代码参考Sub SizeDocumentWindow()
ThisDrawing.Width = 400
ThisDrawing.Height = 400
最小化和最大化活动的“文档”窗口VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("MinMaxDocumentWindow")> _
Public Sub MinMaxDocumentWindow()
''Minimize the Document window
acDoc.Window.WindowState = Window.State.Minimized
MsgBox("Minimized", MsgBoxStyle.SystemModal, "MinMax")
''Maximize the Document window
acDoc.Window.WindowState = Window.State.Maximized
MsgBox("Maximized", MsgBoxStyle.SystemModal, "MinMax")
[CommandMethod("MinMaxDocumentWindow")]
public static void MinMaxDocumentWindow()
//Minimize the Document window
acDoc.Window.WindowState = Window.State.Minimized;
System.Windows.Forms.MessageBox.Show("Minimized" , "MinMax");
//Maximize the Document window
acDoc.Window.WindowState = Window.State.Maximized;
System.Windows.Forms.MessageBox.Show("Maximized" , "MinMax");
VBA/ActiveX 代码参考Sub MinMaxDocumentWindow()
'' Minimize the Document window
ThisDrawing.WindowState = acMin
MsgBox "Minimized"
ThisDrawing.WindowState = acMax
MsgBox "Maximized"
查找活动“文档”窗口的当前状态VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CurrentDocWindowState")> _
Public Sub CurrentDocWindowState()
System.Windows.Forms.MessageBox.Show("The document window is " & _
acDoc.Window.WindowState.ToString(), "Window State")
[CommandMethod("CurrentDocWindowState")]
public static void CurrentDocWindowState()
System.Windows.Forms.MessageBox.Show("The document window is " +
acDoc.Window.WindowState.ToString(), "Window State");
VBA/ActiveX 代码参考Sub CurrentDocWindowState()
Dim CurrWindowState As Integer
Dim msg As String
CurrWindowState = ThisDrawing.WindowState
msg = Choose(CurrWindowState, "Normal", _
"Minimized", "Maximized")
MsgBox "The document window is " + msg
相关概念父主题: |
GMT+8, 2026-11-14 14:22
