Reset 方法 (ActiveX/ATO)
2024-5-18 18:24| 发布者: admin| 查看: 833| 评论: 0|原作者: admin|来自: AutoCAD
根据传递集的根文件重置并重建文件图。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
object.reset()
C#:
object.reset();
类型:TransmittalFilesGraph 对象
此方法应用到的对象。
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalFilesGraph2ITransmittalFilesGraph
  • 该方法是在 AutoCAD 2005 版本的库中引入的。getRootITransmittalFilesGraph2
VB.NET:
' Custom command to work with the transmittal file graph
<CommandMethod("FilesGraph")> _
Public Shared Sub FilesGraph()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Get the root file of the transmittal file graph
    Dim tfRoot As TransmittalFile = tro.getTransmittalGraphInterface().getRoot()
    ' Add a drawing file to a transmittal set
    Dim tfFirst As TransmittalFile = Nothing
    tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg", tfFirst)
    ' Add a second drawing file to a transmittal set
    Dim tfSecond As TransmittalFile = Nothing
    tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", tfSecond)
    ' Display the name and path of the first file of the transmittal file graph
    MsgBox("File name and path: " & tro.getTransmittalGraphInterface().getAt(0).sourcePath)
    ' Display the number of files in the transmittal file graph
    MsgBox("Number of Files in Graph: " & tro.getTransmittalGraphInterface().getNumberOfFiles(vbTrue, vbTrue).ToString())
    ' Display the number of dependees
    MsgBox("Number of Dependees: " & tfFirst.numberOfDependees.ToString())
    ' Create a reference from the first file to the newly added file
    tro.getTransmittalGraphInterface().addEdge(tfSecond, tfFirst)
    ' Remove a reference from the first file
    tro.getTransmittalGraphInterface().removeEdge(tfSecond, tfFirst)
    ' Resets the transmittal graph
    tro.getTransmittalGraphInterface().reset()
    ' Release the tramnsmittal operation
    tro = Nothing
C#:
// Custom command to work with the transmittal file graph
[CommandMethod("FilesGraph")]
public static void FilesGraph()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), @"C:\Users\Public\TransmittalAPITest\");
    // Get the root file of the transmittal file graph
    TransmittalFile tfRoot = tro.getTransmittalGraphInterface().getRoot();
    // Add a drawing file to a transmittal set
    TransmittalFile tfFirst = null;
    tro.addDrawingFile(@"C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg", out tfFirst);
    // Add a second drawing file to a transmittal set
    TransmittalFile tfSecond = null;
    tro.addDrawingFile(@"C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", out tfSecond);
    // Display the name and path of the first file of the transmittal file graph
    System.Windows.MessageBox.Show("File name and path: " + tro.getTransmittalGraphInterface().getAt(0).sourcePath);
    // Display the number of files in the transmittal file graph
    System.Windows.MessageBox.Show("Number of Files in Graph: " + tro.getTransmittalGraphInterface().getNumberOfFiles(1, 1).ToString());
    // Display the number of dependees
    System.Windows.MessageBox.Show("Number of Dependees: " + tfFirst.numberOfDependees.ToString());
    // Create a reference from the root file to the newly added file
    tro.getTransmittalGraphInterface().addEdge(tfSecond, tfFirst);
    // Remove a reference from the root file
    tro.getTransmittalGraphInterface().removeEdge(tfSecond, tfFirst);
    // Resets the transmittal graph
    tro.getTransmittalGraphInterface().reset();
    // Release the tramnsmittal operation
    tro = null;
GMT+8, 2026-11-13 13:20
