CreateTransmittalPackage 方法 (ActiveX/ATO)
根据传递集的文件和设置创建传递包。 支持的平台:仅限 Windows 命名空间:传输塔利布 程序集: acETransmit20.tlb 签名VB.NET: object.createTransmittalPackage() C#: object.createTransmittalPackage();
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本 历史
例子VB.NET: ' Custom command to create a transmittal package with a drawing file
<CommandMethod("eTransmitDWGFile")> _
Public Shared Sub eTransmitDWGFile()
Dim ti As TransmittalInfo = _
TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
' Add a DWG file
Dim tf As TransmittalFile = Nothing
tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", tf)
' Create the transmittal package
' Files are copied and resaved to the path specified by the destinationRoot property
' and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage()
C#: // Custom command to create a transmittal package with a drawing file
[CommandMethod("eTransmitDWGFile")]
public static void eTransmitDWGFile()
TransmittalInfo ti =
TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
// Add a DWG file
TransmittalFile tf = null;
tro.addDrawingFile("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\A-02.dwg", out tf);
// Create the transmittal package
// Files are copied and resaved to the path specified by the destinationRoot property
// and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage();
相关参考 |
GMT+8, 2026-11-12 12:44
