CancelDatabaseNotification 方法 (ActiveX/ATO)
2024-5-18 18:24| 发布者: admin| 查看: 772| 评论: 0|原作者: admin|来自: AutoCAD
注销以前注册的数据库回调通知处理程序。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
object.cancelDatabaseNotification pHandler
C#:
object.cancelDatabaseNotification(pHandler);
类型:TransmittalOperation 对象
此方法应用到的对象。
p处理程序
访问:仅输入
类型:TransmittalDatabaseNotificationHandler 对象
表示为应用程序实现数据库通知的自定义类的对象。
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalOperation2ITransmittalOperation
  • 该方法是在 AutoCAD 2005 版本的库中引入的。cancelDatabaseNotificationITransmittalOperation2
VB.NET:
' Notification handlers
Private Shared g_dbHandler As New MyTransDbNotifier
Private Shared g_fileHandler As New MyTransFileNotifier
Private Shared g_ssmHandler As New MyTransSSMNotifier
' Custom command that subscribes to eTransmit notifications
' Works with the transmittal API and ETRANSMIT/ARCHIVE commands
<CommandMethod("ETNotificationsStart")> _
Public Shared Sub ETNotificationsStart()
    ' Add the handlers
    g_tro.subscribeToAddFileNotification(g_fileHandler)
    g_tro.subscribeDatabaseNotification(g_dbHandler)
    g_tro.subscribeSheetSetNotification(g_ssmHandler)
' Custom command that unsubscribes to eTransmit notifications
<CommandMethod("ETNotificationsEnd")> _
Public Shared Sub ETNotificationsEnd()
    ' Remove the handlers
    g_tro.cancelSubscriptionToAddFileNotification(g_fileHandler)
    g_tro.cancelDatabaseNotification(g_dbHandler)
    g_tro.cancelSheetSetNotification(g_ssmHandler)
C#:
// Notification handlers
private static MyTransDbNotifier g_dbHandler = new MyTransDbNotifier();
private static MyTransFileNotifier g_fileHandler = new MyTransFileNotifier();
private static MyTransSSMNotifier g_ssmHandler = new MyTransSSMNotifier();
// Custom command that subscribes to eTransmit notifications
// Works with the transmittal API and ETRANSMIT/ARCHIVE commands
[CommandMethod("ETNotificationsStart")]
public static void ETNotificationsStart()
    // Add the handlers
    g_tro.subscribeToAddFileNotification(g_fileHandler);
    g_tro.subscribeDatabaseNotification(g_dbHandler);
    g_tro.subscribeSheetSetNotification(g_ssmHandler);
// Custom command that unsubscribes to eTransmit notifications
[CommandMethod("ETNotificationsEnd")]
public static void ETNotificationsEnd()
    // Remove the handlers
    g_tro.cancelSubscriptionToAddFileNotification(g_fileHandler);
    g_tro.cancelDatabaseNotification(g_dbHandler);
    g_tro.cancelSheetSetNotification(g_ssmHandler);
GMT+8, 2026-11-14 18:18
