传递对象库历史记录 (ActiveX/ATO)
对传递对象库所做的添加和更改。 AutoCAD 2020 和基于 AutoCAD 2020 的产品
AutoCAD 2019 和基于 AutoCAD 2019 的产品
接口ITransmittalInfo (Changed)
removeDesignFeed - Property (Removed)
AutoCAD 2018 和基于 AutoCAD 2018 的产品
枚举SaveDwgFormat (Changed)
eAutoCADR32 = 7 (New)
AutoCAD 2017 和基于 AutoCAD 2017 的产品
AutoCAD 2016 和基于 AutoCAD 2016 的产品
AutoCAD 2015 和基于 AutoCAD 2015 的产品
枚举ConvertStatus (Changed)
eEduVersionError = 3 (Removed)
eNotUsed = 3 (New)
removeDesignFeed - Property (New)
基于 AutoCAD 2014 和 AutoCAD 2014 的产品
AutoCAD 2013 和基于 AutoCAD 2013 的产品
eAutoCADR27 = 6 (New)
AutoCAD 2012 和基于 AutoCAD 2012 的产品
AutoCAD 2011 和基于 AutoCAD 2011 的产品
AutoCAD 2010 和基于 AutoCAD 2010 的产品
枚举FileType (Changed)
eDGNUnderlayDependent = 25 (New)
eDwsFile = 26 (New)
ePDFUnderlay = 27 (New)
eAutoCADR24 = 5 (New)
BindType (New)
eBind = 0
eInsert = 1
接口ITransmittalFile (Changed)
targetSubPath - Property (Moved from ITransmittalFile2)
type - Property (Moved from ITransmittalFile2)
includeInTransmittal - Property (Moved from ITransmittalFile2)
numberOfDependents - Property (Moved from ITransmittalFile2)
numberOfDependees - Property (Moved from ITransmittalFile2)
database - Property (Moved from ITransmittalFile2)
getDependent - Method (Moved from ITransmittalFile2)
getDependee - Method (Moved from ITransmittalFile2)
ITransmittalFilesGraph (Changed)
add - Method (Removed)
addEdge - Method (Moved from ITransmittalFilesGraph2)
getAt - Method (Moved from ITransmittalFilesGraph2)
getNumberOfFiles - Method (Moved from ITransmittalFilesGraph2)
getRoot - Method (Moved from ITransmittalFilesGraph2)
remove - Method (Removed)
removeEdge - Method (Moved from ITransmittalFilesGraph2)
reset - Method (Moved from ITransmittalFilesGraph2)
totalBytes - Method (Moved from ITransmittalFilesGraph2)
dataLinkRelativePath - Property (Moved from ITransmittalInfo3)
DGNUnderlayRelativePath - Property (Moved from ITransmittalInfo2)
DWFUnderlayRelativePath - Property (Moved from ITransmittalInfo2)
includeDataLinkFile - Property (Moved from ITransmittalInfo3)
includeDGNUnderlay - Property (Moved from ITransmittalInfo2)
includeDWFUnderlay - Property (Moved from ITransmittalInfo2)
includeMaterialTextureFile - Property (Moved from ITransmittalInfo2)
includeNestedOverlayXrefDwg - Property (New)
includePhotometricWebFile - Property (Moved from ITransmittalInfo3)
includeUnloadedReferences - Property (New)
includeUnloadedXrefDwg - Property (New)
overwriteFileHandler - Property (Removed)
purgeDatabase - Property (New)
visualFidelity - Property (Moved from ITransmittalInfo3)
ITransmittalOperation (Changed)
addDrawingFile - Method (Moved from ITransmittalOperation2)
addFile - Method (Moved from ITransmittalOperation2)
addSheets - Method (Moved from ITransmittalOperation2)
addSheetSelset - Method (Moved from ITransmittalOperation2)
addToReport - Method (Moved from ITransmittalOperation2)
archiveSheetSet - Method (Moved from ITransmittalOperation2)
cancelDatabaseNotification - Method (Moved from ITransmittalOperation2)
cancelSheetSetNotification - Method (Moved from ITransmittalOperation2)
cancelSubscriptionToAddFileNotification - Method (Moved from ITransmittalOperation2)
createTransmittalPackage - Method (Moved from ITransmittalOperation2)
getTransmittalGraphInterface - Method (Moved from ITransmittalOperation2)
getTransmittalInfoInterface - Method (Moved from ITransmittalOperation2/ITransmittalOperation3)
getTransmittalReport - Method (Moved from ITransmittalOperation2)
recalcTargetSubPath - Method (Moved from ITransmittalOperation2)
setProgressMeter - Method (Moved from ITransmittalOperation2)
subscribeDatabaseNotification - Method (Moved from ITransmittalOperation2)
subscribeSheetSetNotification - Method (Moved from ITransmittalOperation2)
subscribeToAddFileNotification - Method (Moved from ITransmittalOperation2)
以下接口已删除/与其父类合并: ITransmittalFile2 (Removed - Moved to ITransmittalFile) ITransmittalFilesGraph2 (Removed - Moved to ITransmittalFilesGraph) ITransmittalInfo2 (Removed - Moved to ITransmittalInfo) ITransmittalInfo3 (Removed - Moved to ITransmittalInfo) ITransmittalOperation2 (Removed - Moved to ITransmittalOperation) ITransmittalOperation3 (Removed - Moved to ITransmittalOperation) AutoCAD 2009 和基于 AutoCAD 2009 的产品
枚举DwgTrustInfo (New)
eDwgUnTrusted = 0xffffffff
eTrustInfoUnavailable = 0
eDwgTrusted = 1
ConvertStatus (New)
eConverted = 0
eSaveError = 1
eRecovered = 2
eShareViolationError = 4
eMissingFiles = 5
eSignedFileError = 6
接口ITransmittalFileOperationOverride (New)
Open - Method (New)
Close - Method (New)
PreProcessHandling - Method (New)
AutoCAD 2008 和基于 AutoCAD 2008 的产品
ePhotometricWebFile = 23 (New)
eDataLinkFile = 24 (New)
接口ITransmittalInfo3 (New)
dataLinkRelativePath - Property (New)
includeDataLinkFile - Property (New)
includePhotometricWebFile - Property (New)
visualFidelity - Property (New)
ITransmittalOperation3 (New)
getTransmittalInfoInterface - Method (New)
ITransmittalFilesGraphPrivate (Changed)
add - Method (Changed to support 64-bit)
nodeAt - Method (Changed to support 64-bit)
AutoCAD 2007 和基于 AutoCAD 2007 的产品
eDGNUnderlay = 20 (New)
eDWFUnderlay = 21 (New)
eMaterialTextureFile = 22 (New)
eAutoCADR21 = 4 (New)
接口ITransmittalInfo2 (Changed)
DGNUnderlayRelativePath - Property (New)
DWFUnderlayRelativePath - Property (New)
includeDGNUnderlay - Property (New)
includeDWFUnderlay - Property (New)
includeMaterialTextureFile - Property (New)
AutoCAD 2006 和基于 AutoCAD 2006 的产品
AutoCAD 2005 和基于 AutoCAD 2005 的产品
eXrefAttachFile = 16 (New)
eXrefOverlayFile = 17 (New)
eSheetSetFile = 18 (New)
eSheetSetSupportFile = 19 (New)
AddFileReturnVal (Changed)
eFileAlreadyAdded = 5 (New)
接口ITransmittalDatabaseNotificationHandler (New)
convertDatabase - Method
postDatabaseProcessing - Method
preDatabaseProcessing - Method
ITransmittalFile2 (New)
database - Property
fileExists - Property
fileSize - Property
lastModifiedTime - Property
sourcePath - Property
type - Property
version - Property
ITransmittalFilesGraph2 (New)
addEdge - Method
getAt - Method
getRoot - Method
removeEdge - Method
reset - Method
totalBytes - Method
ITransmittalInfo2 (New)
defaultOverwriteValue - Property
destinationRoot - Property
imageRelativePath - Property
includeFontFile - Property
includeImageFile - Property
includePlotFile - Property
includeXrefDwg - Property
organizedFolder - Property
plotConfigFilePath - Property
plotStyleTablePath - Property
preserveSubdirs - Property
relativePath - Property
resetPlotter - Property
saveVersion - Property
xrefRelativePath - Property
ITransmittalProgressHandler (New)
isCanceled - Method
processingFile - Method
ITransmittalOperation2 (New)
addFile - Method
addSheets - Method
ITransmittalSheetSetNotification (New)
preSheetSetProcessing - Method
postSheetSetProcessing - Method
AutoCAD 2004 和基于 AutoCAD 2004 的产品
相关参考 |
GMT+8, 2026-11-14 18:27
