BadObjectId 属性 (ActiveX/CSP)
指定其属性与要比较的图形标准文件中定义的对象不匹配的对象的对象 ID。 支持的平台:仅限 Windows 命名空间:AcStMgr (英语) 集会:AcStMgr.tlb 属性值只读:不 类型:LongPtr (长) 与错误关联的对象的对象 ID。 言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub PlugIn_Start(ByVal pStartError As AcStError) _
Implements IAcStPlugin2.Start
' If pStartError is an object, checking should start
' from that error, not the beginning of the current context.
If IsNothing(pStartError) = False Then
' Get the ObjectId of the first object to check
Dim badId As Long = pStartError.BadObjectId
' Find the index for ObjectId in the context list stored in m_objIDArray
For m_curIndex = 0 To m_ContextList.Count - 1
If m_ContextList.Item(m_curIndex) = badId Then
m_curIndex = m_curIndex - 1
PlugIn_Next()
End If
Next
Else
' A valid AcStError object was not passed to the method.
' Checking should start at the beginning of the context list.
m_curIndex = -1
PlugIn_Next()
End If
C#: public void PlugIn_Start(AcStError pStartError)
// If pStartError is an object, checking should start
// from that error, not the beginning of the current context.
if ((pStartError == null) == false)
// Get the ObjectId of the first object to check
long badId = pStartError.BadObjectId;
// Find the index for ObjectId in the context list stored in m_objIDArray
for (m_curIndex = 0; m_curIndex <= m_ContextList.Count - 1; m_curIndex++)
if (Convert.ToInt64(m_ContextList.GetItem(m_curIndex)) == badId)
m_curIndex = m_curIndex - 1;
PlugIn_Next();
else
// A valid AcStError object was not passed to the method.
// Checking should start at the beginning of the context list.
m_curIndex = -1;
PlugIn_Next();
GMT+8, 2026-11-14 18:28
