Start 方法 (ActiveX/CSP)
2024-5-18 18:23| 发布者: admin| 查看: 914| 评论: 0|原作者: admin|来自: AutoCAD
初始化错误检查。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
签名 - AcStErrorIterator 对象
仅供内部使用。
VB.NET:
object.Start([bShowIgnored])
C#:
object.Start([bShowIgnored]);
类型:AcStErrorIterator 对象
此方法应用到的对象。
bShowIgnored
访问:仅输入
类型:布尔
如果错误被标记为忽略,
  • False:不允许检查错误
  • True:允许检查错误
签名 - IAcStPlugin2 接口
VB.NET:
Public Sub Start(pStartError) _
                    Implements IAcStPlugin2.Start
C#:
public void Start(pStartError)
类型:IAcStPlugin2 接口
此方法适用的接口。
pStart错误
访问:仅输入
类型:AcStError 对象
要检查的错误对象。
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Sub PlugIn_Start(ByVal pStartError As AcStError) _
    ' pStartError is not an actual programming error that needs to be handled,
    ' but a reference to an object that does not match the standards
    ' in the DWS file.
    ' If pStartError is an object, checking should start
    ' from that error, not the beginning of the current context.
    If IsNothing(pStartError) = False Then
        ' Get the ObjectId of the first object to check
        Dim badId As Long = pStartError.BadObjectId
        ' Find the index for ObjectId in the context list stored in m_objIDArray
        For m_curIndex = 0 To m_ContextList.Count - 1
            If m_ContextList.Item(m_curIndex) = badId Then
                m_curIndex = m_curIndex - 1
                PlugIn_Next()
            End If
        Next
    Else
        ' A valid AcStError object was not passed to the method.
        ' Checking should start at the beginning of the context list.
        m_curIndex = -1
        PlugIn_Next()
    End If
C#:
public void PlugIn_Start(AcStError pStartError)
    // pStartError is not an actual programming error that needs to be handled,
    // but a reference to an object that does not match the standards
    // in the DWS file.
    // If pStartError is an object, checking should start
    // from that error, not the beginning of the current context.
    if ((pStartError == null) == false)
        // Get the ObjectId of the first object to check
        long badId = pStartError.BadObjectId;
        // Find the index for ObjectId in the context list stored in m_objIDArray
        for (m_curIndex = 0; m_curIndex <= m_ContextList.Count - 1; m_curIndex++)
            if (Convert.ToInt64(m_ContextList.GetItem(m_curIndex)) == badId)
                m_curIndex = m_curIndex - 1;
                PlugIn_Next();
    else
        // A valid AcStError object was not passed to the method.
        // Checking should start at the beginning of the context list.
        m_curIndex = -1;
        PlugIn_Next();
void IAcStPlugin2.Start(AcStError pStartError)
    PlugIn_Start(pStartError);
GMT+8, 2026-11-15 15:21
