ShadowDisplay 属性 (ActiveX)
指定对象的阴影显示属性。(已过时) 支持的平台:仅限 Windows 属性值只读:不 类型:枚举AcShadowDisplayType
言论没有其他评论。 例子VBA: Sub Example_ShadowDisplay()
' This example creates a cone in model space and changes its shadow display setting.
Dim coneObj As Acad3DSolid
Set coneObj = ThisDrawing.ModelSpace.AddCone(centerPoint, 5, 20)
Dim shadowObj As IAcadShadowDisplay
Dim EnableShadowDisplayStatus As Long
Dim ShadowDisplay As AcShadowDisplayType
Dim displaySettingDesc As String
Set shadowObj = coneObj
EnableShadowDisplayStatus = shadowObj.EnableShadowDisplay
ShadowDisplay = shadowObj.ShadowDisplay
displaySettingDesc = DescribeShadowDisplay(ShadowDisplay)
If EnableShadowDisplayStatus = 1 Then
MsgBox "Shadow display is currently enabled for this object." & vbCr & _
"Current shadow display setting is: " & displaySettingDesc
Else
MsgBox "Shadow display is disabled for this object."
End If
shadowObj.ShadowDisplay = acCastsShadows
displaySettingDesc = DescribeShadowDisplay(shadowObj.ShadowDisplay)
MsgBox "New shadow display setting is: " & displaySettingDesc
Private Function DescribeShadowDisplay(acShadow As AcShadowDisplayType) As String
Select Case acShadow
Case acCastsAndReceivesShadows:
DescribeShadowDisplay = "cast and receive shadows."
Case acCastsShadows:
DescribeShadowDisplay = "cast shadows only."
Case acReceivesShadows:
DescribeShadowDisplay = "receive shadows only."
Case acIgnoreShadows:
DescribeShadowDisplay = "ignore shadows."
End Select
End Function
可视化 LISP: (vl-load-com)
(defun c:Example_ShadowDisplay()
;; This example creates a cone in model space and changes its shadow display setting.
;; AutoLISP cannot cast COM objects to different types, so you must change the Shadow Display
;; property via DXF code values.
(setq centerPoint (vlax-3d-point 0 0 0))
(setq coneObj (vla-AddCone modelSpace centerPoint 5 20))
(setq ed (entget (vlax-vla-object->ename coneObj)))
(setq shadowDisplay (assoc 284 ed))
(if (= shadowDisplay nil)
(setq shadowDisplay 0)
(setq shadowDisplay (cdr shadowDisplay))
(setq displaySettingDesc (DescribeShadowDisplay ShadowDisplay))
(alert (strcat "Shadow display is currently enabled for this object."
"\nCurrent shadow display setting is: " displaySettingDesc))
;; Before changing the value, you should validate the object is not a Line or some other
;; 2D object that does not support shadows.
(setq newShadowDisplay acCastsShadows)
(if (/= (assoc 284 ed) nil)
(setq ed (subst (cons 284 acCastsShadows) (assoc 284 ed) ed))
(setq ed (append ed (list (cons 284 acCastsShadows))))
(entmod ed)
(entupd (vlax-vla-object->ename coneObj))
(setq displaySettingDesc (DescribeShadowDisplay newShadowDisplay))
(alert (strcat "New shadow display setting is: " displaySettingDesc))
(defun DescribeShadowDisplay (acShadow / )
(cond
((= acShadow acCastsAndReceivesShadows) "cast and receive shadows.")
((= acShadow acCastsShadows) "cast shadows only.")
((= acShadow acReceivesShadows) "receive shadows only.")
((= acShadow acIgnoreShadows) "ignore shadows.")
GMT+8, 2026-11-13 13:33
