OwnerID32 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 833| 评论: 0|原作者: admin|来自: AutoCAD
获取 64 位系统的所有者(父)对象的对象 ID。(已过时)
只读:是的
类型:长
对象所有者的对象 ID。
Sub Example_OwnerID32()
    ' This example creates an MText object in model space
    ' and then finds the OwnerID for the object.
    Dim MTextObj As AcadMText
    Dim corner(0 To 2) As Double
    Dim width As Double
    Dim text As String
    corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
    width = 10
    text = "This is the text string for the MText object"
    ' Creates the MText object
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    ZoomAll
    MsgBox "The OwnerID for the MText object is: " & MTextObj.OwnerID32
(defun c:Example_OwnerID32()
    ;; This example creates an MText object in model space
    ;; and then finds the OwnerID for the object.
    (setq corner (vlax-3d-point 0 10 0)
          width 10
          text "This is the text string for the MText object")
    ;; Creates the MText object
    (setq MTextObj (vla-AddMText modelSpace corner width text))
    (vla-ZoomAll acadObj)
    (alert (strcat "The OwnerID for the MText object is: " (itoa (vla-get-OwnerID32 MTextObj))))
GMT+8, 2026-11-14 14:37
