LISPCancelled 事件 (ActiveX)
在取消 AutoLISP 表达式的计算时触发。 支持的平台:仅限 Windows 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_LispCancelled()
' This example intercepts a drawing LispCancelled event.
' This event is triggered when the evaluation of a LISP expression is cancelled.
' To trigger this example event: Run a LISP expression and
' cancel the LISP evaluation before it finishes
MsgBox "A LISP evaluation was just cancelled."
可视化 LISP: Not available |
GMT+8, 2026-11-12 12:23
