XRefFadeIntensity 属性 (ActiveX)
控制 XRefs 的调光强度。 支持的平台:仅限 Windows 属性值只读:不 类型:长 从 1 到 90 的正长整数,表示 XRefs 的衰落百分比。 言论此属性的初始值为 50。 注意:此属性的值存储在 XFADECTL 系统变量中。
例子VBA: Sub Example_XRefFadeIntensity()
' This example reads and modifies the preference value that controls
' the dimming intensity for xrefs. When finished, this example resets
' the preference value back to its original value.
' * Note: Changes can only be observed when in-place editing of an Xref
' object is in progress and other entities are visible.
Dim ACADPref As AcadPreferencesDisplay
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
originalValue = ACADPref.XRefFadeIntensity
MsgBox "The XRefFadeIntensity preference is: " & originalValue
' Modify the XRefFadeIntensity preference by setting it to 75
ACADPref.XRefFadeIntensity = 75
newValue = ACADPref.XRefFadeIntensity
MsgBox "The XRefFadeIntensity preference has been set to: " & newValue
' this preference in effect
ACADPref.XRefFadeIntensity = originalValue
MsgBox "The XRefFadeIntensity preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_XRefFadeIntensity()
;; This example reads and modifies the preference value that controls
;; the dimming intensity for xrefs. When finished, this example resets
;; the preference value back to its original value.
;; * Note: Changes can only be observed when in-place editing of an Xref
;; object is in progress and other entities are visible.
(setq originalValue (vla-get-XRefFadeIntensity (vla-get-Display preferences)))
(alert (strcat "The XRefFadeIntensity preference is: " (itoa originalValue)))
;; Modify the XRefFadeIntensity preference by setting it to 75
(vla-put-XRefFadeIntensity (vla-get-Display preferences) 75)
(alert (strcat "The XRefFadeIntensity preference has been set to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences)))))
;; this preference in effect
(vla-put-XRefFadeIntensity (vla-get-Display preferences) originalValue)
(alert (strcat "The XRefFadeIntensity preference was reset back to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences)))))
GMT+8, 2026-11-14 18:17
