XRefDatabase 属性 (ActiveX)
获取定义块内容的 Database 对象。 支持的平台:仅限 Windows 言论仅当块的属性等于 时,此属性才可用。IsXRefTrue 例子VBA: Sub Example_XRefDatabase()
' This example adds an external reference to the current drawing.
' It then cycles through each Block object in the drawing
' and determines the style of each Block by accessing the
' IsLayout and IsXRef properties of the Block. If the Block is an
' XRef Block, you obtain a reference to the external Database object
' for that Block and display the number of Blocks the Database contains.
Dim InsertPoint(0 To 2) As Double
Dim insertedBlock As AcadExternalReference
Dim tempBlock As AcadBlock
Dim msg As String, PathName As String
' Define external reference to be inserted
InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
PathName = "c:\program files\autocad\sample\city map.dwg"
' Add the external block to model space
Set insertedBlock = ThisDrawing.ModelSpace.AttachExternalReference(PathName, "XREF_IMAGE", InsertPoint, 1, 1, 1, 0, False)
msg = vbCrLf & vbCrLf
For Each tempBlock In ThisDrawing.Blocks
If tempBlock.IsXRef Then
' Block is an external reference, so add it to list
msg = msg & tempBlock.name & " contains " & _
tempBlock.XRefDatabase.Blocks.count & " blocks"
msg = msg & vbCrLf ' Insert line
End If
Next
' Display Block information for the XRefDatabase
MsgBox "Externally referenced blocks attached to this drawing have the following block counts: " & msg
可视化 LISP: (vl-load-com)
(defun c:Example_XRefDatabase()
;; This example adds an external reference to the current drawing.
;; It then cycles through each Block object in the drawing
;; and determines the style of each Block by accessing the
;; IsLayout and IsXRef properties of the Block. If the Block is an
;; XRef Block, you obtain a reference to the external Database object
;; for that Block and display the number of Blocks the Database contains.
;; Define external reference to be inserted
(setq InsertPoint (vlax-3d-point 1 1 0)
pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
;; Add the external block to model space
(setq insertedBlock (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" InsertPoint 1 1 1 0 :vlax-false))
(vla-ZoomAll acadObj)
(setq msg "")
(vlax-for tempBlock (vla-get-Blocks doc)
(if (= (vla-get-IsXRef tempBlock) :vlax-true)
(progn
;; Block is an external reference, so add it to list
(setq msg (strcat msg (vla-get-Name tempBlock) " contains "
(itoa (vla-get-Count (vla-get-Blocks (vla-get-XRefDatabase tempBlock)))) " blocks\n"))
;; Display Block information for the XRefDatabase
(alert (strcat "Externally referenced blocks attached to this drawing have the following block counts: " msg))
GMT+8, 2026-11-12 12:28
