WindowTop 属性 (ActiveX)
指定应用程序窗口的上边缘。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 应用程序窗口的上边缘。 言论应用程序的上边缘由从主应用程序窗口的上边缘到屏幕上边缘的距离决定。 此距离将建立应用程序左上角的 Y 坐标。请注意,原点 (0, 0) 是左上角。 例子VBA: Sub Example_WindowTop()
' This example finds the WindowTop (X coordinate) of the WindowTop of the
' AutoCAD window. It then changes that position to be 100 more
' than it currently is. Finally, it resets the window to the
' original value.
' Find the current value of the WindowTop property
Dim currWindowTop As Integer
currWindowTop = ThisDrawing.Application.WindowTop
MsgBox "The current value of WindowTop is " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
' Change the value of WindowTop
ThisDrawing.Application.WindowTop = currWindowTop + 100
MsgBox "The new value of WindowTop is " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
' Reset the value of WindowTop
MsgBox "The value of WindowTop has been reset to " & ThisDrawing.Application.WindowTop, , "WindowTop Example"
可视化 LISP: (vl-load-com)
(defun c:Example_WindowTop()
;; This example finds the WindowTop (X coordinate) of the WindowTop of the
;; AutoCAD window. It then changes that position to be 100 more
;; than it currently is. Finally, it resets the window to the
;; original value.
;; Find the current value of the WindowTop property
(setq currWindowTop (vla-get-WindowTop acadObj))
(alert (strcat "The current value of WindowTop is " (itoa currWindowTop)))
;; Change the value of WindowTop
(vla-put-WindowTop acadObj (+ currWindowTop 100))
(alert (strcat "The new value of WindowTop is " (itoa (vla-get-WindowTop acadObj))))
;; Reset the value of WindowTop
(vla-put-WindowTop acadObj currWindowTop)
(alert (strcat "The value of WindowTop has been reset to " (itoa (vla-get-WindowTop acadObj))))
GMT+8, 2026-11-12 12:24
