WindowState 属性 (ActiveX)
指定应用程序或文档窗口的状态。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acWindowState
言论没有其他评论。 例子VBA: Sub Example_WindowState()
' This example reads and displays the current window state of the AutoCAD application.
Dim CurrentState As String
' Use the "WindowState" variable to determine the window state of AutoCAD
Select Case WindowState
Case acMin: CurrentState = "Minimized"
Case acMax: CurrentState = "Maximized"
Case acNorm: CurrentState = "Normal Size"
End Select
' Display window state
MsgBox "AutoCAD is now: " & CurrentState
可视化 LISP: (vl-load-com)
(defun c:Example_WindowState()
;; This example reads and displays the current window state of the AutoCAD application.
;; Use the "WindowState" variable to determine the window state of AutoCAD
(setq CurrentState (cond
((= (vla-get-WindowState acadObj) acMin) "Minimized")
((= (vla-get-WindowState acadObj) acMax) "Maximized")
((= (vla-get-WindowState acadObj) acNorm) "Normal Size")
;; Display window state
(alert (strcat "AutoCAD is now: " CurrentState))
GMT+8, 2026-11-14 15:05
