Weights 属性 (ActiveX)
获取样条曲线的权重向量。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 样条曲线的权重向量。 言论没有其他评论。 例子VBA: Sub Example_Weights()
' This example creates a Spline object in model space and
' returns the weight vector for the new Spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
Dim weightVector As Variant
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
' Add weights to the Spline
splineObj.SetWeight 0, 1.5
splineObj.SetWeight 1, 2
splineObj.SetWeight 2, 4.5
' Display the weight vector of the new Spline
weightVector = splineObj.Weights
MsgBox "The weight vector of the new Spline is: " & vbCrLf & _
weightVector(0) & vbCrLf & _
weightVector(1) & vbCrLf & _
weightVector(2)
可视化 LISP: (vl-load-com)
(defun c:Example_Weights()
;; This example creates a Spline object in model space and
;; returns the weight vector for the new Spline
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Add weights to the Spline
(vla-SetWeight splineObj 0 1.5)
(vla-SetWeight splineObj 1 2)
(vla-SetWeight splineObj 2 4.5)
;; Display the weight vector of the new Spline
(setq weightVector (vlax-variant-value (vla-get-Weights splineObj)))
(alert (strcat "The weight vector of the new Spline is: "
"\n" (rtos (vlax-safearray-get-element weightVector 0) 2)
"\n" (rtos (vlax-safearray-get-element weightVector 1) 2)
"\n" (rtos (vlax-safearray-get-element weightVector 2) 2)))
GMT+8, 2026-11-13 13:36
