Verify 属性 (ActiveX)
指定是否为验证设置属性。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论设置为验证的属性会提示用户在插入块时验证属性值是否正确。 属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。AFLAGS 系统变量存储当前模式设置。可以使用 Mode 属性查询当前模式。 例子VBA: Sub Example_Verify()
' This example creates an attribute definition in model space.
' It then sets the definition to be verify, and queries the mode.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "New_Tag"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
' Change the mode to be verify
attributeObj.mode = acAttributeModeVerify
attributeObj.Update
' Check to see if the attribute is set to verify
MsgBox (IIf(attributeObj.Verify, "The attribute is set to verify", "The attribute is not set to verify"))
可视化 LISP: (vl-load-com)
(defun c:Example_Verify()
;; This example creates an attribute definition in model space.
;; It then sets the definition to be verify, and queries the mode.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "New_Tag"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
;; Change the mode to be verify
(vla-put-Mode attributeObj acAttributeModeVerify)
(vla-Update attributeObj)
;; Check to see if the attribute is set to verify
(alert (if (= (vla-get-Verify attributeObj) :vlax-true) "The attribute is set to verify" "The attribute is not set to verify"))
GMT+8, 2026-11-15 15:07
