UseStandardScale 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 846| 评论: 0|原作者: admin|来自: AutoCAD
指定绘图是使用标准比例还是自定义比例。
object.UseStandardScale
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:使用标准比例绘制。
  • False:使用自定义比例进行打印。
若要指定要在绘图中使用的标准比例,请使用该属性。若要指定自定义比例,请使用该方法。StandardScaleSetCustomScale
Sub Example_UseStandardScale()
    ' This example will access the Layouts collection for the current drawing
    ' and list the status of UseStandardScale for each Layout.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    msg = ""
    ' Get the UseStandardScale information of every layout in this drawing
    For Each Layout In Layouts
        If Layout.UseStandardScale Then
            msg = msg & Layout.name & " uses the standard scale." & vbCrLf
        Else
            msg = msg & Layout.name & " uses a custom scale." & vbCrLf
        End If
    Next
    ' Display the information
    MsgBox msg
(defun c:Example_UseStandardScale()
    ;; This example will access the Layouts collection for the current drawing
    ;; and list the status of UseStandardScale for each Layout.
    ;; Get layouts collection from document object
    (setq Layouts (vla-get-Layouts doc)
          msg "")
    ;; Get the UseStandardScale information of every layout in this drawing
    (vlax-for Layout Layouts
        (if (= (vla-get-UseStandardScale Layout) :vlax-true)
            (setq msg (strcat msg (vla-get-Name Layout) " uses the standard scale.\n"))
            (setq msg (strcat msg (vla-get-Name Layout) " uses a custom scale.\n"))
    ;; Display the information
    (alert msg)
GMT+8, 2026-11-12 12:26
