UpsideDown 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 601| 评论: 0|原作者: admin|来自: AutoCAD
指定文本的方向。
object.UpsideDown
类型:属性、属性引用、文本
此属性应用于的对象。
只读:不
类型:布尔
  • True:文本颠倒。
  • False:文本不是颠倒的。
Sub Example_UpsideDown()
    ' This example creates a text object in model space and
    ' uses the UpsideDown property to flip the text vertically
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the new Text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    height = 0.5
    ' Create the Text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    MsgBox "The Text oject is now right side up"
    textObj.UpsideDown = True
    ThisDrawing.Regen acActiveViewport
    MsgBox "The Text object is now upside down"
(defun c:Example_UpsideDown()
    ;; This example creates a text object in model space and
    ;; uses the UpsideDown property to flip the text vertically
    ;; Define the new Text object
    (setq insertionPoint (vlax-3d-point 3 3 0)
          textString "Hello, World."
          height 0.5)
    ;; Create the Text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    (alert "The Text oject is now right side up")
    (vla-put-UpsideDown textObj :vlax-true)
    (vla-Regen doc acActiveViewport)
    (alert "The Text object is now upside down")
GMT+8, 2026-11-12 12:22
