UCSIconOn 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 644| 评论: 0|原作者: admin|来自: AutoCAD
指定 UCS 图标是否打开。
object.UCSIconOn
类型:PViewport、视口
此属性应用于的对象。
只读:不
类型:布尔
  • True:UCS 图标亮起。
  • False:UCS 图标熄灭。
Sub Example_UCSIconOn()
    ' This example toggles the setting of UCSIconOn.
    Dim viewportObj As AcadViewport
    ' Set the viewportObj variable to the activeviewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Display the current setting of UCSIconOn
    MsgBox "UCSIcon is: " & IIf(viewportObj.UCSIconOn, "On", "Off"), , "UCSIconOn Example"
    ' Toggle the setting of UCSIconOn
    viewportObj.UCSIconOn = Not (viewportObj.UCSIconOn)
    ' Reset the active viewport to see the change
    ThisDrawing.ActiveViewport = viewportObj
    MsgBox "UCSIcon is now: " & IIf(viewportObj.UCSIconOn, "On", "Off"), , "UCSIconOn Example"
(defun c:Example_UCSIconOn()
    ;; This example toggles the setting of UCSIconOn.
    ;; Set the viewportObj variable to the activeviewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Display the current setting of UCSIconOn
    (alert (strcat "UCSIcon is: " (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) "On" "Off")))
    ;; Toggle the setting of UCSIconOn
    (vla-put-UCSIconOn viewportObj (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) :vlax-false :vlax-true))
    ;; Reset the active viewport to see the change
    (vla-put-ActiveViewport doc viewportObj)
    (alert (strcat "UCSIcon is now: " (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-11-13 13:39
