TurnHeight 属性 (ActiveX)
指定螺旋线一整圈的高度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 一整圈的高度。 言论没有其他评论。 例子VBA: Sub Example_Helix_BaseRadius()
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_HELIX")
Dim mode As Integer
ssetObj.SelectOnScreen
Dim obj As AcadEntity
Dim helix As AcadHelix
Dim helixBaseRadius As Double
Dim objName As String
For Each obj In ssetObj
objName = obj.ObjectName
If TypeOf obj Is AcadHelix Then
Set helix = obj
helix.BaseRadius = helix.BaseRadius * 2
MsgBox "Baseradius of helix is doubled to " & helix.BaseRadius * 2
End If
Next
ssetObj.Delete
Sub Example_Helix_TopRadius()
Dim mode As Integer
Set helix = obj
helix.TopRadius = helix.TopRadius * 0.5
MsgBox "Top radius of helix is halved to " & helix.TopRadius * 0.5
End If
Next
ssetObj.Delete
Sub Example_Helix_Direction()
Dim mode As Integer
Set helix = obj
If helix.Twist = acCCW Then
helix.Twist = acCW
Else
helix.Twist = acCCW
End If
MsgBox "Direction is reversed"
End If
Next
ssetObj.Delete
Sub Example_Helix_Height()
Dim mode As Integer
Set helix = obj
helix.Constrain = acHeight
helix.height = helix.height * 2
MsgBox "Height doubled"
End If
Next
ssetObj.Delete
Sub Example_Helix_Turns()
Dim mode As Integer
Set helix = obj
helix.Constrain = acTurns
helix.Turns = helix.Turns * 2
MsgBox "Turns doubled"
End If
Next
ssetObj.Delete
Sub Example_Helix_TurnHeight()
Dim mode As Integer
Set helix = obj
helix.Constrain = acTurnHeight
helix.TurnHeight = helix.TurnHeight * 2
MsgBox "Turns height doubled"
End If
Next
ssetObj.Delete
可视化 LISP: (vl-load-com)
(defun c:Example_Helix_BaseRadius()
(setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_HELIX"))
(vla-SelectOnScreen ssetObj)
(vlax-for obj ssetObj
(setq objName (vla-get-ObjectName obj))
(if (= objName "AcDbHelix")
(progn
(setq helix obj)
(vla-put-BaseRadius helix (* (vla-get-BaseRadius helix) 2))
(alert (strcat "Baseradius of helix is doubled to " (rtos (vla-get-BaseRadius helix) 2)))
(vla-Delete ssetObj)
(defun c:Example_Helix_TopRadius()
(progn
(setq helix obj)
(vla-put-TopRadius helix (* (vla-get-TopRadius helix) 0.5))
(alert (strcat "Top radius of helix is halved to " (rtos (vla-get-TopRadius helix) 2)))
(defun c:Example_Helix_Direction()
(progn
(setq helix obj)
(if (= (vla-get-Twist helix) acCCW)
(vla-put-Twist helix acCW)
(vla-put-Twist helix acCCW)
(alert "Direction is reversed")
(defun c:Example_Helix_Height()
(progn
(setq helix obj)
(vla-put-Constrain helix acHeight)
(vla-put-Height helix (* (vla-get-Height helix) 2))
(alert "Height doubled")
(defun c:Example_Helix_Turns()
(progn
(setq helix obj)
(vla-put-Constrain helix acTurns)
(vla-put-Turns helix (* (vla-get-Turns helix) 2))
(alert "Turns doubled")
(defun c:Example_Helix_TurnHeight()
(progn
(setq helix obj)
(vla-put-Constrain helix acTurnHeight)
(vla-put-TurnHeight helix (* (vla-get-TurnHeight helix) 2))
(alert "Turns height doubled")
GMT+8, 2026-11-13 17:21
