Transparency 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 847| 评论: 0|原作者: admin|来自: AutoCAD
指定特定双调图像的透明度是打开还是关闭。
object.Transparency
类型:GeomapImage、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:布尔
  • True:透明度已打开。
  • False:透明度已关闭。
双调光栅图像是仅由前景色和背景色组成的图像。附着半位图像时,整个图像将继承当前颜色图层设置。除了可以对任何附加图像进行修改外,还可以通过打开和关闭背景的透明度来修改半调图像。
注意:双调图像和双调图像边界始终是相同的颜色。
Sub Example_Transparency()
    ' This example inserts a raster image and finds the current status
    ' of Transparency for the image. It then changes the Transparency
    ' status of the image.
    ' This example uses the "2d Projected Polylines.jpg" found in the sample
    ' directory. If you do not have the image, or it is located
    ' in a different directory, insert a valid path and name for the
    ' imageName variable below.
    Dim scalefactor As Double
    Dim rotAngleInDegree As Double, rotAngle As Double
    Dim imageName As String
    Dim raster As AcadRasterImage
    imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
    insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotAngleInDegree = 0#
    rotAngle = rotAngleInDegree * 3.141592 / 180#
    On Error Resume Next
    ' Creates a raster image in model space
    Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
    If Err.Description = "Filer error" Then
        MsgBox imageName & " could not be found."
        Exit Sub
    End If
    ' Find the current Transparency
    ThisDrawing.Regen True
    MsgBox "The Transparency is currently set to: " & raster.transparency, vbInformation
    ' Change the Transparency
    If (raster.transparency) Then
        raster.transparency = False
    Else
        raster.transparency = True
    End If
    MsgBox "The Transparency is now set to: " & raster.transparency, vbInformation
(defun c:Example_Transparency()
    ;; This example inserts a raster image and finds the current status
    ;; of Transparency for the image. It then changes the Transparency
    ;; status of the image.
    ;; This example uses the "2d Projected Polylines.jpg" found in the sample
    ;; directory. If you do not have the image, or it is located
    ;; in a different directory, insert a valid path and name for the
    ;; imageName variable below.
    (setq insertionPoint (vlax-3d-point 2 2 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 1
          rotAngle (/ (* 0 3.141592) 180))
    (if (/= (findfile imageName) nil)
        (progn
            ;; Creates a raster image in model space
            (setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotAngle))
            (vla-ZoomExtents acadObj)
            ;; Find the current Transparency
            (vla-Regen doc :vlax-true)
            (alert (strcat "The Transparency is currently set to: " (if (= (vla-get-Transparency raster) :vlax-true) "True" "False")))
            ;; Change the Transparency
            (vla-put-Transparency raster (if (= (vla-get-Transparency raster) :vlax-true) :vlax-false :vlax-true))
            (alert (strcat "The Transparency is currently now set to: " (if (= (vla-get-Transparency raster) :vlax-true) "True" "False")))
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-11-13 13:46
