TotalAngle 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 750| 评论: 0|原作者: admin|来自: AutoCAD
获取圆弧的总角度。
object.TotalAngle
类型:弧形
此属性应用于的对象。
只读:是的
类型:双
弧的总长度(以弧度为单位)。
Sub Example_TotalAngle()
    ' This example creates an Arc in model space and
    ' returns the total angle of the new Arc
    Dim arcObj As AcadArc
    Dim radius As Double
    Dim startAngleInDegree As Double, endAngleInDegree As Double
    Dim startAngleInRadian As Double, endAngleInRadian As Double
    ' Define the Arc
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    startAngleInDegree = 10#: endAngleInDegree = 230#
    ' Convert the angles in degrees to angles in radians
    startAngleInRadian = startAngleInDegree * 3.141592 / 180#
    endAngleInRadian = endAngleInDegree * 3.141592 / 180#
    ' Create the arc object in model space
    Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
    ' Return length of new arc
    MsgBox "The total angle of the new Arc is: " & arcObj.TotalAngle
(defun c:Example_TotalAngle()
    ;; This example creates an Arc in model space and
    ;; returns the total angle of the new Arc
    ;; Define the arc
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5
          startAngleInDegree 10
          endAngleInDegree 230)
    ;; Convert the angles in degrees to angles in radians
    (setq startAngleInRadian (/ (* startAngleInDegree 3.141592) 180))
    (setq endAngleInRadian (/ (* endAngleInDegree 3.141592) 180))
    ;; Create the arc object in model space
    (setq arcObj (vla-AddArc modelSpace centerPoint radius startAngleInRadian endAngleInRadian))
    (vla-ZoomAll acadObj)
    ;; Return length of new arc
    (alert (strcat "The total angle of the new Arc is: " (rtos (vla-get-TotalAngle arcObj) 2)))
GMT+8, 2026-11-14 14:29
