Top 属性 (ActiveX)
指定工具栏的上边缘。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 工具栏的上边缘。 言论没有其他评论。 例子VBA: Sub Example_Top()
' This example creates a new toolbar called and inserts a
' button into it. The toolbar is then displayed and the top
' position is returned.
' To remove the toolbar after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new toolbar
Dim newToolBar As AcadToolbar
Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
' Add a button to the new toolbar.
Dim newButton1 As AcadToolbarItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
' Display the toolbar
newToolBar.Visible = True
'Find the top position
Dim currTop As Integer
currTop = newToolBar.Top
MsgBox "The current value of Top is " & newToolBar.Top, , "Top Example"
' Change the value of Top
newToolBar.Top = currTop + 100
MsgBox "The new value of Top is " & newToolBar.Top, , "Top Example"
' Reset the value of Top
MsgBox "The value of Top has been reset to " & newToolBar.Top, , "Top Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Top()
;; This example creates a new toolbar called and inserts a
;; button into it. The toolbar is then displayed and the top
;; position is returned.
;; To remove the toolbar after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new toolbar
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
;; Add a button to the new toolbar.
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
;; Display the toolbar
(vla-put-Visible newToolBar :vlax-true)
;; Find the top position
(setq currTop (vla-get-Top newToolBar))
(alert (strcat "The current value of Top is " (itoa currTop)))
;; Change the value of Top
(vla-put-Top newToolBar (+ currTop 100))
(alert (strcat "The new value of Top is " (itoa (vla-get-Top newToolBar))))
;; Reset the value of Top
(vla-put-Top newToolBar currTop)
(alert (strcat "The value of Top has been reset to " (itoa (vla-get-Top newToolBar))))
GMT+8, 2026-11-12 12:29
