Toolbars 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 661| 评论: 0|原作者: admin|来自: AutoCAD
获取 Toolbars 集合。
object.Toolbars
类型:MenuGroup
此属性应用于的对象。
只读:是的
类型:工具栏
声明为集合的用户指定的变量。Toolbars
Sub Example_Toolbars()
    ' This example finds the names of the all toolbars in the first menu group.
    Dim toolbarNames As String
    Dim toolbarCollection As AcadToolbars
    Dim toolbar As AcadToolbar
    Set toolbarCollection = ThisDrawing.Application.MenuGroups.Item(0).Toolbars
    toolbarNames = ""
    For Each toolbar In toolbarCollection
        toolbarNames = toolbarNames & toolbar.name & vbCrLf
    Next toolbar
    MsgBox toolbarNames
(defun c:Example_Toolbars()
    ;; This example finds the names of the all toolbars in the first menu group.
    (setq toolbarCollection (vla-get-Toolbars (vla-Item (vla-get-MenuGroups acadObj) 0))
          toolbarNames "")
    (vlax-for toolbar toolbarCollection
        (setq toolbarNames (strcat toolbarNames (vla-get-Name toolbar) "\n"))
    (alert toolbarNames)
GMT+8, 2026-11-14 14:24
