ToleranceSuppressZeroInches 属性 (ActiveX)
指定在公差值中隐含零英寸测量值。 支持的平台:仅限 Windows 签名VBA: object.ToleranceSuppressZeroInches
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMTZIN 系统变量的值。
例子VBA: Sub Example_ToleranceSuppressZeroInches()
' uses ToleranceSuppressZeroInches to toggle the display of zeros inches
' in the dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 6.01: point2(1) = 5: point2(2) = 0
location(0) = 5: location(1) = 8: location(2) = 0
dimObj.UnitsFormat = acDimLArchitectural
' Enable and setup tolerance display
dimObj.ToleranceDisplay = acTolLimits
dimObj.ToleranceLowerLimit = -95#: dimObj.ToleranceUpperLimit = 95#
ZoomAll
Toggle:
Select Case MsgBox("Press OK to toggle the display of zero inches in the dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of zero inches for the dimension tolerance value
dimObj.ToleranceSuppressZeroInches = Not (dimObj.ToleranceSuppressZeroInches)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceSuppressZeroInches()
;; uses ToleranceSuppressZeroInches to toggle the display of zeros inches
;; in the dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 6.01 5 0)
location (vlax-3d-point 5 8 0))
(vla-put-UnitsFormat dimObj acDimLArchitectural)
;; Enable and setup tolerance display
(vla-put-ToleranceDisplay dimObj acTolLimits)
(vla-put-ToleranceLowerLimit dimObj -95)
(vla-put-ToleranceUpperLimit dimObj 95)
(vla-ZoomAll acadObj)
;; Toggle the display of zero inches for the dimension tolerance value
(vla-put-ToleranceSuppressZeroInches dimObj (if (= (vla-get-ToleranceSuppressZeroInches dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of zero inches toggled.")
;; Toggle the display of zero inches for the dimension tolerance value back to previous state
(alert "Suppression of zero inches toggled back.")
GMT+8, 2026-11-13 17:20
