ToleranceJustification 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 917| 评论: 0|原作者: admin|来自: AutoCAD
指定公差值相对于标称尺寸文本的垂直对齐方式。
object.ToleranceJustification
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimToleranceJustify
  • acTolTop
  • acTolMiddle
  • acTolBottom
此属性的初始值为 。acTolMiddle
仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone
注意:此属性将覆盖给定维度的 DIMTOLJ 系统变量的值。
Sub Example_ToleranceJustification()
    ' sets the tolerance justification for the dimension to
    ' a couple of common values
    ' * Note the vertical position of the tolerance text
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    Dim CurrentDisplay As String
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Turn on tolerance display and increase the dimension text height,
    ' so the alignment of the tolerance is visible
    dimObj.ToleranceDisplay = acTolSymmetrical
    dimObj.textHeight = 1
    dimObj.ToleranceHeightScale = 0.25
    ' Read and display the current tolerance justification for this dimension
    Select Case dimObj.ToleranceJustification
        Case acTolBottom: CurrentDisplay = "Bottom"
        Case acTolTop: CurrentDisplay = "Top"
        Case acTolMiddle: CurrentDisplay = "Middle"
    End Select
    MsgBox "The tolerance justification is currently: " & CurrentDisplay
    ' Set the tolerance justification for this dimension
    dimObj.ToleranceJustification = acTolBottom
    ' Display the current tolerance justification for this dimension
    MsgBox "The tolerance display is now set to: Bottom"
(defun c:Example_ToleranceJustification()
    ;; sets the tolerance justification for the dimension to
    ;; a couple of common values
    ;; * Note the vertical position of the tolerance text
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    ;; Turn on tolerance display and increase the dimension text height,
    ;; so the alignment of the tolerance is visible
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-put-TextHeight dimObj 1)
    (vla-put-ToleranceHeightScale dimObj 0.25)
    (vla-ZoomAll acadObj)
    ;; Read and display the current tolerance justification for this dimension
    (setq currentDisplay (cond
                             ((= (vla-get-ToleranceJustification dimObj) acTolBottom) "Bottom")
                             ((= (vla-get-ToleranceJustification dimObj) acTolTop) "Top")
                             ((= (vla-get-ToleranceJustification dimObj) acTolMiddle) "Middle")
    (alert (strcat "The tolerance justification is currently: " currentDisplay))
    ;; Set the tolerance justification for this dimension
    (vla-put-ToleranceJustification dimObj acTolBottom)
    ;; Display the current tolerance justification for this dimension
    (alert "The tolerance display is now set to: Bottom")
GMT+8, 2026-11-14 14:28
