TextStyles 属性 (ActiveX)
获取文档的 TextStyles 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_TextStyles()
' This example finds the current Textstyles collection and
' adds a new Text style to that collection.
Dim TextColl As AcadTextStyles
Set TextColl = ThisDrawing.TextStyles
' Create a Text style named "TEST" in the current drawing
Dim textStyle As AcadTextStyle
Set textStyle = TextColl.Add("TEST")
MsgBox "A new Text style called " & textStyle.name & " has been added to the Textstyles collection.", vbInformation, "Textstyles Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextStyles()
;; This example finds the current Textstyles collection and
;; adds a new Text style to that collection.
(setq TextColl (vla-get-TextStyles doc))
;; Create a Text style named "TEST" in the current drawing
(setq textStyle (vla-Add TextColl "TEST"))
(alert (strcat "A new Text style called " (vla-get-Name textStyle) " has been added to the Textstyles collection."))
GMT+8, 2026-11-13 13:29
