TextLeftAttachmentType 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 772| 评论: 0|原作者: admin|来自: AutoCAD
指定左侧的引线如何与文本连接。
object.TextLeftAttachmentType
类型:MLeader、MLeaderStyle
此属性应用于的对象。
只读:不
类型:枚举AcTextAttachmentType
  • acAttachmentAllLine
  • acAttachmentBottomLine
  • acAttachmentBottomOfBottom
  • acAttachmentBottomOfTop
  • acAttachmentBottomOfTopLine
  • acAttachmentMiddle
  • acAttachmentMiddleOfBottom
  • acAttachmentMiddleOfTop
  • acAttachmentTopOfTop
Sub Example_TextManipulation()
    Dim oML As AcadMLeader
    Dim points(0 To 14) As Double
    ' Define the leader points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    Dim i As Long
    Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
    oML.TextLeftAttachmentType = acAttachmentBottomLine
    oML.TextRightAttachmentType = acAttachmentMiddleOfBottom
    oML.TextBackgroundFill = False
    oML.TextDirection = acLeftToRight
    oML.TextHeight = 2.3
    oML.TextJustify = acAttachmentPointMiddleLeft
    oML.TextLineSpacingDistance = 2.4
    oML.TextLineSpacingFactor = 1.2
    oML.TextLineSpacingStyle = acLineSpacingStyleExactly
    oML.TextWidth = 7.4
(defun c:Example_TextManipulation()
    ;; Define the leader points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
    (vlax-safearray-fill points '(1 1 0
                                  1 2 0
                                  2 2 0
                                  3 2 0
                                  4 4 0
    (setq i 0)
    (setq oML (vla-AddMLeader modelSpace points i))
    (vla-put-TextLeftAttachmentType oML acAttachmentBottomLine)
    (vla-put-TextRightAttachmentType oML acAttachmentMiddleOfBottom)
    (vla-put-TextBackgroundFill oML :vlax-false)
    (vla-put-TextDirection oML acLeftToRight)
    (vla-put-TextHeight oML 2.3)
    (vla-put-TextJustify oML acAttachmentPointMiddleLeft)
    (vla-put-TextLineSpacingDistance oML 2.4)
    (vla-put-TextLineSpacingFactor oML 1.2)
    (vla-put-TextLineSpacingStyle oML acLineSpacingStyleExactly)
    (vla-put-TextWidth oML 7.4)
GMT+8, 2026-11-13 13:47
