TextInsideAlign 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 849| 评论: 0|原作者: admin|来自: AutoCAD
指定除纵坐标外的所有尺寸类型的延伸线内尺寸文本的位置。
object.TextInsideAlign
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:水平对齐文本。
  • False:将文本与尺寸线对齐。
此属性的初始值为 。True
仅当该属性设置为 时,此属性才可用。TextInsideTrue
注意:此属性将覆盖给定维度的 DIMTIH 系统变量的值。
Sub Example_TextInsideAlign()
    ' allows the user to toggle the TextInsideAlign value for the dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 6: point2(2) = 0
    dimObj.TextInside = True    ' The TextInsideAlign property will only work
                                ' when this property is active
Toggle:
    Select Case MsgBox("Press OK to toggle the TextInsideAlign value for this dimension", vbOKCancel)
        Case vbOK
            ' Toggle the TextInsideAlign value for this dimension
            dimObj.TextInsideAlign = Not (dimObj.TextInsideAlign)
            ' Read and display the new dimension TextInsideAlign value
            MsgBox "TextInsideAlign is currently set to: " & dimObj.TextInsideAlign
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_TextInsideAlign()
    ;; allows the user to toggle the TextInsideAlign value for the dimension
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 6 0)
    (vla-put-TextInside dimObj :vlax-true)    ;; The TextInsideAlign property will only work
                                              ;; when this property is active
    (vla-ZoomAll acadObj)
    ;; Toggle the TextInsideAlign value for this dimension
    (vla-put-TextInsideAlign dimObj (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) :vlax-false :vlax-true))
    ;; Read and display the new dimension TextInsideAlign value
    (alert (strcat "TextInsideAlign is currently set to: " (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) "True" "False")))
GMT+8, 2026-11-12 12:18
