TextInside 属性 (ActiveX)
指定是否要在扩展线内绘制尺寸文本。 支持的平台:仅限 Windows 签名VBA: object.TextInside
属性值只读:不 类型:布尔
言论此属性的初始值为 。True 将此属性设置为具有不同的结果。对于线性尺寸和角度尺寸,如果有足够的空间,AutoCAD 会将文本放置在扩展线内。对于不适合圆或圆弧的半径和直径尺寸,此属性不起作用,并且始终强制文本超出圆或圆弧。False 注意:此属性将覆盖给定维度的 DIMTIX 系统变量的值。
例子VBA: Sub Example_TextInside()
' allows the user to toggle, forcing the dimension text between the extension lines
' using the TextInside property
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
Toggle:
Select Case MsgBox("Press OK to toggle forcing the dimension text inside the extension lines", vbOKCancel)
Case vbOK
' Toggle forcing the dimension text inside the extension lines
dimObj.TextInside = Not (dimObj.TextInside)
' Read and display the new dimension TextInside value
CurrentValue = IIf(dimObj.TextInside, "is now", "is not")
MsgBox "The dimension text " & CurrentValue & " forced inside the extension lines"
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_TextInside()
;; allows the user to toggle, forcing the dimension text between the extension lines
;; using the TextInside property
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Toggle forcing the dimension text inside the extension lines
(vla-put-TextInside dimObj (if (= (vla-get-TextInside dimObj) :vlax-true) :vlax-false :vlax-true))
;; Read and display the new dimension TextInside value
(setq CurrentValue (if (= (vla-get-TextInside dimObj) :vlax-true) "is now" "is not"))
(alert (strcat "The dimension text " CurrentValue " forced inside the extension lines"))
GMT+8, 2026-11-14 14:27
